Page 1 of 2
LOXX Electronic Doorlock
Posted: Fri Feb 15, 2008 9:38 pm
Soon to be released the Loxx electronic Doorlock. I have seen a demo of this electronic lock today and it looks very promising.
Loxx turns every lock in a electronic lock
- can be opened by remote control
- after closing automatic on night lock
- Easy to install
- Battery operated
- can also be opened with traditional key stored in remote (still small remote)
- SKG citified / encrypted code
(Dutch)
LoXX maakt van ieder slot een elektrisch slot
- Met afstandbediening te openen
- Na dichtduwen automatisch op nachtschoot
- Makkelijk te installeren, geen hak & breekwerk
- Batterijgevoed dus geen bedrading
- Past op elk bestaand slot, meerpuntsluiting en veiligheidsbeslag
- Een mechanische sleutel in handzender
- Bij nood gegarandeerde vluchtweg
- Veilig, SKG goedgekeurd / encrypted code
- Betaalbaar
http://www.loxx.nl/opeenkier.html
Pieter Knuvers
Posted: Sat Feb 16, 2008 2:46 am
by Dowser
Sure, looks nice, but what with the lack of a proper handle?!?
But if you like this one, look at Assa 3000.
It has a proper handle, secure hook-deadbolt and Assa's proven track-record.
They have more information about it at http://www.assa3000.se but for some reason I can't find any information about it translated.
(Ha! Payback for all .nl links! :D )
Personally I have switched to the Assa 2002 system, that basically is the same system, but without the remote. They launched the 3000 product line a few weeks after I got mine installed... :(
//Markus
Posted: Sat Feb 16, 2008 3:00 am
There is a handle, thats the knob. If you turn it around the door will open!
it's also more safe, in the Netherlands houses are broken in via the mailbox which is in the door.
Posted: Sat Feb 16, 2008 11:35 am
by TANE
look nice.
hoop the price will also be okay.
was there any possibility to connect the key to the existing domotica components.
Posted: Sat Feb 16, 2008 1:10 pm
Yes, I have seen a setup where it was connect to the Cellphone Doorbell (GSM Deurbel Waleli http://www.gsmdeurbel.nl) There is a small printcircuit, in fact the print of the remote control, which has printconnection to adapt in a existing home automation setup. There is also an extra small sensor on the door, so when the door closes it gives an extra signal to the lock telling it to savelock the door. So the lock is closed. This is a lock which does not go over your existing key, you get a new key, which can be stored in the remote. Still the remote is very small. As I said the demo looked very promising, I hope to get a model for testing soon. I don't now the price yet but I keep you all posted!
regards Pieter
Posted: Sat Feb 16, 2008 2:56 pm
by Snelvuur
maybe just in time for my house :)
Posted: Sat Feb 16, 2008 5:10 pm
by Esteban
Nice stainless steel look, I like it. From the website I understand this isn't available yet?
EDIT: Duh, you already said "Soon to be released" in the opening post, I should read better...
[Off topic]
Last week I was browsing a bit looking at some locks aswell and found this one for pretty cheap, too bad it's only for indoor use... so apartments and offices only.
MyKey2300 (199 dollars (136 euros) + tax&postage)
http://www.mykey2300.com/
I found a review of it on YouTube. It starts at 3min 5sec:
Looks pretty solid and I like the way they solved the problem of running out of batteries and power outtage and being able to power the lock from outside if necessary...
[/Off topic]
Posted: Sun Feb 17, 2008 12:05 am
by DJF3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dowser</i>
<br />Sure, looks nice, but what with the lack of a proper handle?!?
//Markus
Markus, where can you buy these locks in the Netherlands? (and what is the approx. price?)
Posted: Sun Feb 17, 2008 12:43 am
by TANE
Thats good News...:)
I don't like to have more than 1 keyfob with me.
With the abus system I have connected
the lock door to the X10 network
Open door to the Visonic Alarm Aux
<br />Yes, I have seen a setup where it was connect to the Cellphone Doorbell (GSM Deurbel Waleli http://www.gsmdeurbel.nl) There is a small printcircuit, in fact the print of the remote control, which has printconnection to adapt in a existing home automation setup. There is also an extra small sensor on the door, so when the door closes it gives an extra signal to the lock telling it to savelock the door. So the lock is closed. This is a lock which does not go over your existing key, you get a new key, which can be stored in the remote. Still the remote is very small. As I said the demo looked very promising, I hope to get a model for testing soon. I don't now the price yet but I keep you all posted!
regards Pieter
Posted: Sun Feb 17, 2008 2:59 am
Both look very good. And i hope the price of the LOXX will be ok, since most equivalent doorlocks are quite expensive; too expensive to be really interesting to the "average domotican".
Posted: Mon Feb 18, 2008 10:07 am
by Esteban
@Digit: I have to agree, the prices of some of these locks are just a little expensive for... a lock. It says 'betaalbaar' (affordable) in the description but that doesn't mean it's cheap ;) A reliable and reasonably priced lock would be a nice addition.
Posted: Fri Oct 31, 2008 4:00 am
by cvonken
Loxx has updated their website with more info on the Loxx One and additional accesoires.
Also, an introduction price of 349,= (ex vat) is now mentioned.
A nice add-on is the use of a Sorex wirelesskey, which allows a bluetooth enabled phone to open your door (Sorex and One for 499,= ex vat).
You should be able to check this out on the "Beurs Domotica & Slim Wonen" in Eindhoven on november 19+20.
Posted: Fri Oct 31, 2008 9:24 am
by TANE
The new addon's looks very interesting.
I hope that the domotica interface will be available soon.
Robert also your wall switch is there...:)
Posted: Fri Oct 31, 2008 10:15 am
Loxx One and the Sorex Bluetooth is 599 Euro Ex vat
this is the folder http://www.loxx.nl/NL/downloads/LoXX-Sorex_A4.pdf
This looks good the doorlock recognize your phone, sends a encrypted key and opens the door.
www.loxx.nl
Posted: Fri Oct 31, 2008 2:33 pm
by Snelvuur
I wonder about those range options, i dont want my door to open if i'am just going to the toilet, and passing the front door for instance.
