Konig SEC-ASDW10 door / window sensor
turboproc
Post by turboproc »
did someone already discover the coding used by the Konig SEC-ASDW10 door / window sensor? Coding of other Konig devices is probbly similar.
I made some steps starting with the HEZ Jeenode decoder, changing the timing and including Manchester decoding. Results however are still inconsistant and understanding the protocol is still a big questionmark. The constant factor is an 8 byte sequence starting with 30 2E ...
Thanks for any help.
