Cant connect extern to ipcam
Moderator: Esteban
Edwin
Post by Edwin »
Hi , i have a ipcam on 192.168.2.105 on port 82
I can connect to it at home but no from outsite.
I did open port 82 in the router (back an forwards)
When i want to view it for example on my iphone
I put in my external adress:82 and the loginname and password of the camera
But nothing happens.
But if i do the same with the internal ip it works,
This is the same on other pc's
What is wrong? (Beside my english) ;-)
Thanks edwin
Re: Cant connect extern to ipcam
but nothing happens.
So you get the login of the camera, but no image?
mhn
Post by mhn »
Is your Default gateway correct on the ipcam?
Regards
Morten
Edwin
Post by Edwin »
mhn wrote:Is your Default gateway correct on the ipcam?
Regards
Morten
Default gateway 192.168.2.1 is my router is this ok?
I have set a "steady" ip 192.168.2.105
I cant see the login page
The page doesnt load at all
Open ports, or port redirection?
the last one you need
mhn
Post by mhn »
Yes that is the correct gateway.
Like Bwired says, it must be something on your firewall then.
Maybe time to find the firewall log? :-)
Regards
Morten
Willem4ever
Post by Willem4ever »
Hmm. what kind of router do you have ? and did you set some forwarding from your external ip:port to your internal ip:port
Edwin
Post by Edwin »
Willem4ever wrote:Hmm. what kind of router do you have ? and did you set some forwarding from your external ip:port to your internal ip:port
i have the d-link dir 655
i did open ports to 192.168.2.105 opened port 82
can you explain what you mean or how to do that
Willem4ever
Check out page 56 in your manual and create a mapping between your internal ip:port and external:ip port ...
Goodluck !
Edwin
Post by Edwin »
Willem4ever wrote:Check out page 56 in your manual and create a mapping between your internal ip:port and external:ip port ...
Goodluck !
i get this in the log of the router:Dropped packet from 192.168.2.105 to 255.255.255.255 (IP protocol 6) as unable to create new session
[INFO] Thu Nov 22 19:51:02 2012 UPnP added entry 255.255.255.255 <-> xxxxxxxxxxxx:82 <-> 192.168.2.105:82 TCP timeout:0 'voortuin'
[INFO] Thu Nov 22 19:49:59 2012 Dropped packet from 192.168.2.105 to 255.255.255.255 (IP protocol 6) as unable to create new session
Willem4ever
that is an old log entry [INFO] Thu Nov 22 19:51:02 or is your clock not set correctly ? Are you really using UPnP, if not switch it off !
Edwin
Post by Edwin »
Willem4ever wrote:that is an old log entry [INFO] Thu Nov 22 19:51:02 or is your clock not set correctly ? Are you really using UPnP, if not switch it off !
was a new log but time and date are both wrong
You need Port forwarding, not open ports
use the second menu option "Port forwarding"
Edwin
Post by Edwin »
Bwired wrote:You need Port forwarding, not open ports
Ok thanks i'll try that ;-)
Edwin
Post by Edwin »
Thanks Bert, that was it
Very stupid of me, i thought that i had to open the ports in virtual server.
Shame shame shame
