Just wondering. Is something forthcoming that enables the new RFXtrx433 USB 433.92MHz to receive Visonic 868 MHz PIR's. E.g a slave like the one for the RFXLAN Transceiver.
If I understand it correctly the RFXtrx433 USB 433.92MHz is compatible with Visonic, but only with the legacy 433,92 MHz components.
I just find the RFXLAN Transceiver 433.92 MHz + Visonic Slave 868 MHz receiver quite expensive.
Thanks
Marck
Visonic receiver 868 MHz
- b_weijenberg
Re: Visonic receiver 868 MHz
There is an USB 868 version http://www.rfxcom.com/store/Receivers/10106
The RFXtrx433 cannot have an additional slave installed.
Thank you very much.
One more question. Is this USB 868.95MHz receiver for Visonic sensors supported by Homeseer?
Thanks
Thanks
- b_weijenberg
