Gateway problem with Remeha Avant and Celcia 20
Posted: Sun Dec 16, 2012 6:32 pm
Hello all,
I build assembled and tested the gateway, all seems to be fine.
I can communicate with the OTGW with a computer and see the OT messages passing by.
After startup the Celcia is also responding fine.
However after 4 to 5 OT messages the gateway reports Error 01 and some times Error 03, the Celcia reports error 203.
When the OTGW is put in monitor mode (GW=0 ) everything is fine again.
The command IT=1/0 does not help. Changes the reference voltage also does not help.
I am suspecting timing issues, but do not have a clue where to start debugging.
Any ideas?
Herman
Any ideas?
Herman
