Hi All,
I have a Greenwave Powernode 6 which has been working perfectly with my Raspberry Pi and Aeon Labs Z-Wave S2 for a week now - except until Saturday evening. At some point *all* of the sensor values reset to 0 and will not change. I can query the node using the Open Z-Wave control, get all sorts of node information through the python API, but all sensor values return 0.
Does anybody else have this problem with their Z-Wave devices? I can't find any other information about this online, which is unfortunate. Any help would be appreciated!
D.
PS I'm not using DomotiGa or Homeseer since both require an actual desktop and I run a headless raspberry pi, so everything is browser based or command line
ZWave sensor zero output
Re: ZWave sensor zero output
I think you use the open-zwave library? Ifso, check the OZW_Log.txt and checkout what is coming from the network.
ps. DomotiGa(Server) can also run headless ... only no "nice" WebGUI exist (yet).
Okay well, I have no idea what I did but I unplugged the switch completely, put it back in, reset my raspberry pi and now everything works. I have no idea why this worked. I'm still curious if anybody else has had this issue with their Powernode 6.
uAlex73: Yeah I checked what was coming from the network - I couldn't see any obvious errors, just zero values coming from the sensors like:
i=3 listening=1 flirs=0
node = 3 id = 1 value = 0 precision = 4
node = 3 id = 13 value = 0 precision = 4
node = 3 id = 17 value = 0 precision = 4
node = 3 id = 21 value = 0 precision = 4
node = 3 id = 25 value = 0 precision = 4
node = 3 id = 29 value = 0 precision = 4
etc.
I did actually check out the headless mode of DomotiGa(Server) but the lack of a "nice" WebGUI and the ability to control and configure it through the web kind of killed it for me. I have to admit I didn't spend much time on figuring out if it had a command line interface yet or API that I could hook into.
etc.
I think the problem is with the powerbar.
I have one powerbar en 3 single port units from Nuon and once in a while the single port units stop reporting data. I think they hang up on bad z-wave network respone (they seem to have poor z-wave reception)
