Instellingen gmail
Posted: Mon May 20, 2013 8:20 am
by Edwin
Zou iemand de instellingen van gmail door willen sturen samen met het configfile van stunnel?
Ik krijg het niet werkend.
Alvast bedankt.
Groeten
Edwin
Re: Instellingen gmail
Posted: Mon May 20, 2013 10:29 am
by AshaiRey
Hoi Edwin,
Zo werkt het bij mij
Email on HS / setup page settings
Sending Server (SMTP): smtp.gmail.com:25
Receiving Server (POP): localhost:110
Use MAPI for E-Mail: NO
SMTP Username/pwd : invullen
De default to/ftom/subject/message
De rest is leeg
STUNNEL.INI
; Sample stunnel configuration file for Win32 by Michal Trojnara 2002-2012
; Some options used here may be inadequate for your particular configuration
; This sample file does *not* represent stunnel.conf defaults
; Please consult the manual for detailed description of available options
; * Global options *
; Debugging stuff (may useful for troubleshooting)
;debug = 7
;output = stunnel.log
; Disable FIPS mode to allow non-approved protocols and algorithms
;fips = no
; * Service defaults may also be specified in individual service sections *
; Certificate/key is needed in server mode and optional in client mode
cert = stunnel.pem
;key = stunnel.pem
; Authentication stuff needs to be configured to prevent MITM attacks
; It is not enabled by default!
;verify = 2
; Don't forget to c_rehash CApath
;CApath = certs
; It's often easier to use CAfile
;CAfile = certs.pem
; Don't forget to c_rehash CRLpath
;CRLpath = crls
; Alternatively CRLfile can be used
;CRLfile = crls.pem
; Disable support for insecure SSLv2 protocol
options = NO_SSLv2
; Workaround for Eudora bug
;options = DONT_INSERT_EMPTY_FRAGMENTS
; These options provide additional security at some performance degradation
;options = SINGLE_ECDH_USE
;options = SINGLE_DH_USE
; * Service definitions (at least one service has to be defined) *
; Example SSL server mode services
[pop3s]
;accept = 995
;connect = 110
client = yes
accept = 127.0.0.1:110
connect = pop.gmail.com:995
[imaps]
;accept = 993
;connect = 143
client = yes
accept = 127.0.0.1:143
connect = imap.gmail.com:993
[ssmtp]
;accept = 465
;connect = 25
client = yes
accept = 127.0.0.1:25
connect = smtp.gmail.com:465
; Example SSL client mode services
;[gmail-pop3]
;client = yes
;accept = 127.0.0.1:110
;connect = pop.gmail.com:995
;[gmail-imap]
;client = yes
;accept = 127.0.0.1:143
;connect = imap.gmail.com:993
;[gmail-smtp]
;client = yes
;accept = 127.0.0.1:25
;connect = smtp.gmail.com:465
; Example SSL front-end to a web server
;[https]
;accept = 443
;connect = 80
; "TIMEOUTclose = 0" is a workaround for a design flaw in Microsoft SSL
; Microsoft implementations do not use SSL close-notify alert and thus
; they are vulnerable to truncation attacks
;TIMEOUTclose = 0
; vim:ft=dosini
IN GMAIL onder instellingen
POP inschakelen
IMAP uitschakelen
GMAIL kopie behouden in postvak IN
Hoop dat dit je helpt
Posted: Mon May 20, 2013 11:20 am
by Edwin
Bedankt voor je reactie .
Ik ga ermee aan de slag.
Posted: Mon May 20, 2013 12:27 pm
by Edwin
AshaiRey wrote:Hoi Edwin,
De rest is leeg
STUNNEL.INI
;debug = 7
;fips = no
cert = stunnel.pem
;key = stunnel.pem
;verify = 2
;CApath = certs
;CAfile = certs.pem
;CRLpath = crls
;CRLfile = crls.pem
options = NO_SSLv2
[pop3s]
;accept = 995
;connect = 110
client = yes
[imaps]
;accept = 993
;connect = 143
client = yes
[ssmtp]
;accept = 465
;connect = 25
client = yes
;[gmail-pop3]
;client = yes
;[gmail-imap]
;client = yes
;[gmail-smtp]
;client = yes
;[https]
;accept = 443
;connect = 80
;TIMEOUTclose = 0
; vim:ft=dosini
POP inschakelen
IMAP uitschakelen
Ik heb de instellingen geprobeerd die jij gebruikt krijg dan deze foutmelding in hslog:20-5-2013 12:18:44 - Error - Sending email using SMTP: De server heeft het adres van de afzender geweigerd. Reactie van server: 530 5.7.0 Must issue a STARTTLS command first. c42sm36610498eeb.10 - gsmtp
wat moet ik aanpassen?
alvast bedankt.
Posted: Tue May 21, 2013 9:17 am
by AshaiRey
Geen idee.
Heb je al in het stunnel log gekeken?
Posted: Tue May 21, 2013 10:21 am
by Edwin
Zal het logje vanavond er even bij zetten.
Posted: Tue May 21, 2013 1:58 pm
by AshaiRey
Het lijkt me beter als je zelf eerst in het log kijk om te zien wat er gebeurd. Ik kan niet in je systeem kijken hoe alles geconfigureerd is namelijk.
Zoals het er staat werkt het bij mij na stevig puzzelen. Na een jaar of wat geleden weet ik ook niet meer wat er is gebeurd
Posted: Tue May 21, 2013 6:57 pm
by Edwin
heb mijn log bekeken maar weet niet of er iets fout is,kan iemand aub even kijken?
bedankt.
stunnel log:
2013.05.20 19:22:42 LOG5[1968:4504]: stunnel 4.56 on x86-pc-msvc-1500 platform
2013.05.20 19:22:42 LOG5[1968:4504]: Compiled/running with OpenSSL 1.0.1e-fips 11 Feb 2013
2013.05.20 19:22:42 LOG5[1968:4504]: Threading:WIN32 Sockets:SELECT,IPv6 SSL:ENGINE,OCSP,FIPS
2013.05.20 19:22:42 LOG5[1968:4504]: Reading configuration from file stunnel.conf
2013.05.20 19:22:42 LOG5[1968:4504]: FIPS mode is enabled
2013.05.20 19:22:43 LOG5[1968:4504]: Configuration successful
2013.05.21 12:10:42 LOG5[1968:4504]: Reading configuration from file stunnel.conf
2013.05.21 12:10:42 LOG5[1968:4504]: FIPS mode is enabled
2013.05.21 12:10:42 LOG5[1968:4504]: Configuration successful
2013.05.21 12:18:35 LOG5[1968:4504]: Reading configuration from file stunnel.conf
2013.05.21 12:18:35 LOG5[1968:4504]: FIPS mode is enabled
2013.05.21 12:18:35 LOG5[1968:4504]: Configuration successful
2013.05.21 12:18:35 LOG7[1968:4504]: Service [pop3s] (FD=428) bound to 0.0.0.0:110
2013.05.21 12:18:35 LOG7[1968:4504]: Service [imaps] (FD=424) bound to 0.0.0.0:993
2013.05.21 12:18:35 LOG7[1968:4504]: Service [ssmtp] (FD=688) bound to 0.0.0.0:25
2013.05.21 12:18:35 LOG7[1968:4504]: Signal pipe is empty
2013.05.21 12:23:14 LOG7[1968:4504]: Dispatching signals from the signal pipe
2013.05.21 12:23:14 LOG7[1968:4504]: Processing SIGNAL_REOPEN_LOG
2013.05.21 12:23:14 LOG5[1968:4504]: Log file reopened
2013.05.21 12:23:14 LOG7[1968:4504]: Signal pipe is empty
2013.05.21 18:37:39 LOG7[1968:4504]: Service [ssmtp] accepted (FD=700) from 219.142.42.9:26866
2013.05.21 18:37:39 LOG7[1968:4504]: Creating a new thread
2013.05.21 18:37:39 LOG7[1968:4504]: New thread created
2013.05.21 18:37:39 LOG7[1968:1808]: Service [ssmtp] started
2013.05.21 18:37:39 LOG5[1968:1808]: Service [ssmtp] accepted connection from 219.142.42.9:26866
2013.05.21 18:37:39 LOG6[1968:1808]: connect_blocking: connecting 74.125.136.108:465
2013.05.21 18:37:39 LOG7[1968:1808]: connect_blocking: s_poll_wait 74.125.136.108:465: waiting 10 seconds
2013.05.21 18:37:39 LOG5[1968:1808]: connect_blocking: connected 74.125.136.108:465
2013.05.21 18:37:39 LOG5[1968:1808]: Service [ssmtp] connected remote server from 192.168.2.197:4857
2013.05.21 18:37:39 LOG7[1968:1808]: Remote socket (FD=620) initialized
2013.05.21 18:37:39 LOG7[1968:1808]: SNI: sending servername: smtp.gmail.com
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): before/connect initialization
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 write client hello A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 read server hello A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 read server certificate A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 read server done A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 write client key exchange A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 write change cipher spec A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 write finished A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 flush data
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 read server session ticket A
2013.05.21 18:37:39 LOG7[1968:1808]: SSL state (connect): SSLv3 read finished A
2013.05.21 18:37:39 LOG7[1968:1808]: 1 items in the session cache
2013.05.21 18:37:39 LOG7[1968:1808]: 1 client connects (SSL_connect())
2013.05.21 18:37:39 LOG7[1968:1808]: 1 client connects that finished
2013.05.21 18:37:39 LOG7[1968:1808]: 0 client renegotiations requested
2013.05.21 18:37:39 LOG7[1968:1808]: 0 server connects (SSL_accept())
2013.05.21 18:37:39 LOG7[1968:1808]: 0 server connects that finished
2013.05.21 18:37:39 LOG7[1968:1808]: 0 server renegotiations requested
2013.05.21 18:37:39 LOG7[1968:1808]: 0 session cache hits
2013.05.21 18:37:39 LOG7[1968:1808]: 0 external session cache hits
2013.05.21 18:37:39 LOG7[1968:1808]: 0 session cache misses
2013.05.21 18:37:39 LOG7[1968:1808]: 0 session cache timeouts
2013.05.21 18:37:39 LOG7[1968:1808]: Peer certificate was cached (2266 bytes)
2013.05.21 18:37:39 LOG6[1968:1808]: SSL connected: new session negotiated
2013.05.21 18:37:39 LOG6[1968:1808]: Negotiated TLSv1/SSLv3 ciphersuite: AES128-SHA (128-bit encryption)
2013.05.21 18:37:39 LOG6[1968:1808]: Compression: null, expansion: null
2013.05.21 18:37:39 LOG3[1968:1808]: readsocket: Connection reset by peer (WSAECONNRESET) (10054)
2013.05.21 18:37:39 LOG5[1968:1808]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket
2013.05.21 18:37:39 LOG7[1968:1808]: Remote socket (FD=620) closed
2013.05.21 18:37:39 LOG7[1968:1808]: Local socket (FD=700) closed
2013.05.21 18:37:39 LOG7[1968:1808]: Service [ssmtp] finished (0 left)
Posted: Thu May 23, 2013 4:31 pm
by Uriel
Edwin, heb je de stunnel.conf geprobeerd die ik je had gemaild? Werkt het nu?
Posted: Thu May 23, 2013 6:06 pm
by Edwin
Ik heb gisteren de instelling van localhost veranderd in 127.0.0.1 en nu werkt het wel.
Raar maar waar.
Bedankt voor je hulp
Groeten edwin
Posted: Fri May 24, 2013 2:32 pm
by Uriel
Dat is goed, ben blij dat ik je kon helpen. Heb toendertijd ook lang gezocht.
Posted: Sat May 25, 2013 10:40 am
by AshaiRey
Edwin wrote:Ik heb gisteren de instelling van localhost veranderd in 127.0.0.1 en nu werkt het wel.
Raar maar waar.
Groeten edwin
Blij te horen dat het werkt.
(Trouwens Localhost is de netbios naam voor 127.0.0.1 en zou ook in je hots file aanwezig moeten zijn.)
Posted: Tue Nov 26, 2013 5:49 pm
by DJF3
STUNNEL.INI
[ssmtp]
client = yes
Why would you configure Homeseer to use '
smtp.gmail.com:25' as sending server if you can use a
secure connection by pointing to
127.0.0.1:25?
Posted: Wed Nov 27, 2013 10:05 am
by AshaiRey
No idea, i didn't think of it either
Probaly some leftover from a previous try from a few year back. In the beginning i had email working via HomeSeer but that got broken in time and didn't work any more. (gmail started to use secure connections only for pop)
