Greenwave PowerNode (Nuon Smartplug 6) no updates
Posted: Thu Sep 05, 2013 11:47 am
by MarFan
I bought an Nuon Smartplug 6 (=Greenwave).
This I can monitor with my Razberry Z-wave solution. I can see all data (Sensor+Meter) and control each node (switch).
BUT. the data is not updating. I have to push the Update button in the z-wave UI myself ???
Is there any setup which will force to update every 1-5-10 seconds the values ???
Re: Greenwave PowerNode (Nuon Smartplug 6) no updates
Posted: Thu Sep 05, 2013 11:52 pm
I have a Razberry too but haven't done much with it yet.
But what I can remember is that the demo web-intf that comes with the Razberry does the same, with AJAX IIRC.
So maybe it's needed. What does the manual say?
Posted: Fri Sep 06, 2013 4:13 pm
by geert-jan
I have 2 nuon/greenwave smartplugs in use; power usage data (actual + total) must be polled, the data is not send automatically by the smartplug.
I am running a (homeseer) script that polls the smartplugs at a regular interval, so the status in Homeseer is almost up-to-date.
Reagrds,
Geert-Jan
Posted: Fri Sep 06, 2013 5:38 pm
by MarFan
Can you share the script ? Or is it integrated in HomeSeer ?
I did some search (google) to find that sort of scripts (or JSON url) but cannot find anything
Found it
The command is : IpAddressRP:8083/ZWaveAPI/Run/devices[X].instances[Y].Meter.Get()
Where X= device number
Y : 0 All plugs together
Y : 1-6 plug Y of the Powernode
So I created a script, which poll every 2 second 1 plug.
Thanks for helping
Posted: Wed Oct 16, 2013 4:40 pm
by christiand
For a getting a readout only polling the root device should be sufficient. No need to poll every separated device. Also be carefull with your poll interfall. 2 seconds is quite aggressive and could created a zwave command queue
