i tried to update my plugwise today. to work with the plugwise plugin
it went well until the network tried to build up again .none of the plugs was recognized, i can see in the source (versie2.23)
that the stick with firmware (2011-6-27)was recognized.but the circle+ and the others plugs couldn't be recognized and they have firmware(2008-8-26) (sorry for my English)
how to solve this?
thanks.
edwin
problem after Plugwise update
Re: problemen na update
please translate:-)
Re: problem after Plugwise update
i had same problem in the past
can you put the old version back and first update the circles firmware?
2008 is very old, my oldest is from 4-2010..............
How to get the old firmware on the stick then?Bwired wrote:i had same problem in the past
Thanks
Edwin
You better contact PlugWise directly and see what they can do for you....
/Rien
/Rien
Het is weer opgelost.
Plugwise heeft de oude versie opgestuurd,
Toen alles van vooraf aan opnieuw moeten doen en nu werkt alles weer.
Gr.
Edwin
Gr.
Edwin
