Everspring SP814 motion sensor
Posted: Mon Oct 07, 2013 7:59 pm
by basklj
I managed to add the everspring sp814 to my homeseer system, and made an association within group 1 with homeseer. However when i want to change the parameters in order to adjust sensitivity level, lux level setting etc the configuration value is set at ERROR and cannot be saved when changed.
Anyone experience with this?
Re: Everspring SP814 motion sensor
Posted: Mon Oct 07, 2013 10:43 pm
by mhn
You have to wake up battery devices, and send the changes just after.
Regards
Morten
Posted: Tue Oct 08, 2013 12:39 am
by GertK
It would be helpful to have a step-by-step description here how to configure this e.g. in Homeseer II.
Gert
Posted: Tue Oct 08, 2013 12:05 pm
by basklj
mhn wrote:You have to wake up battery devices, and send the changes just after.
Regards
Morten
Thank you Morten, I will give that a try.
Posted: Wed Oct 09, 2013 3:51 pm
by raymonvdm
I also have an SP814 but after 2 days it goes blind. (until battery re-seat) What settings are you trying maybe i can check ?
Posted: Wed Oct 09, 2013 10:46 pm
by basklj
raymonvdm wrote:I also have an SP814 but after 2 days it goes blind. (until battery re-seat) What settings are you trying maybe i can check ?
Mine is not going blind and I still use the factory settings, I can provide you with the factory settings if you want but maybe a total reset is easier
Posted: Wed Oct 09, 2013 10:47 pm
by basklj
Regards
Morten
Its working, thank you for your advice
You happen to know how to use the lux settings/readings in a device/ event?
Posted: Thu Oct 10, 2013 7:44 am
by mhn
My guess is you can use Device Value Change.
Regards
Morten
Posted: Wed Oct 16, 2013 9:05 am
by burekwilles
basklj wrote:I managed to add the everspring sp814 to my homeseer system, and made an association within group 1 with homeseer. However when i want to change the parameters in order to adjust sensitivity level, lux level setting etc the configuration value is set at ERROR and cannot be saved when changed.
Previously I do have that SP814 and believe me it was like really horrible since after every 3rd or 4th day it goes blind and it just like a very irritating thing for me so I decided to change it by foscam and it works great no problem at all.
Posted: Wed Oct 16, 2013 3:41 pm
by raymonvdm
Foscam ?
