I do not now where and on witch pins i must make the 1-wire sensors.
Is there some one that will explane to me how i kan make more 1-wire device to my RPi.
Or a link where i can find the right pin out, and the good way to make the 1-wire working, etc.
Only how do i get the unic code of the Sensors?
And the code: sudo modprobe w1-gpio is not working, or do i have first the sensor on it?
Can i make in this string the BMP085 on the same way?
I don`t think it can be connected in the same way. I don`t think it is an 1-wire device. However you can connect it to another gpio pin there are several available on the Pi
@ All,
It looks like that i bin there allmost..
1 question how do i get the uniqe id, from all the different sensors? Do I get this when i do this tutoriol: cl.cam.ac.uk/projects/raspberrypi/tutor ... mperature/
Is that id for always? or is the sensor evertime get a new id when i connect it to the Rpi?
How do i mark this sensor in Domoticz...? Or in my documentation.?
I would like to learn a new application for home automation that uses 1-wire sensors (DS18B20, ds2438) Modbus instruments. domotic-dream is an opensource software like LAMP distributed for free under the GNU GPL3. domotic-dream preinstalled on raspberry and can be downloaded from sourceforge. anyone who wants to use or develop other plugins, to connect to http://www.domotic-dream.com or http://sourceforge.net/projects/domotic ... =directory
