Zwave.me switch goes off automatically
Posted: Thu Oct 10, 2013 8:16 pm
by christiand
Since a couple of weeks I have a problem with 2 zwave.me (ZME_06431) switches. When I turn them on manually i hear the click and the light goes on. But strange enough the light goes automatically off within a few seconds. When that happens I don't hear the click in the switch. If I want to turn the light on I have to press the off button first before I can try again.
At first this was only with one switch but after a while a second switch got the same problem. Both switches are on the same power line. But on the same powerline I have 2 duwi switches which have no problem.
I already tried:
  • Removed them from the controller
  • Checked and enforced parameter 2 to 0. This parameter is the automatic off in seconds.0 disabled this
  • Switched the power off
Has anybody had the same problem and hopefully can provide help?
Re: Zwave.me switch goes off automatically
Posted: Thu Oct 10, 2013 10:13 pm
by Akatar
i have the same with one me switch
i guess you can sent them back to the shop where you bought them
Posted: Thu Oct 10, 2013 10:57 pm
by raymonvdm
I have had this issue with a none Zwave.me version and it was broken. (Relay power dropped due to faulty hardware)
Posted: Sun Oct 13, 2013 12:46 am
by christiand
Not the answer i was hoping for :-( Think i will go with fibaro modules as a replacement. Thank you for the replies
Posted: Tue Oct 15, 2013 4:12 pm
by raymonvdm
Are you claiming warranty or just throw them away ?
Posted: Wed Oct 16, 2013 4:27 pm
by christiand
I have contacted the shop and explained the problem. But i am going to switch to fibaro modules because of the better compatibility with homeseer.
Posted: Thu Feb 27, 2014 9:21 am
by christiand
I forgot to post an update, so here it is. The shop explained that a batch of zwave.me was not very stable. Since I now use primarily fibaro modules cause I can want to use my own switching materials which is based on jung.
The shop was kind enough to take back the zwave.me modules and gave me a discount on the fibaro modules
