Fibaro Binary Sensor FGBS-001
Forum all about Z-Wave Fibaro
kriz83
Post by kriz83 »
I have a question regarding this sensor.
It states that it has 2 inputs and 2 outputs. Can you control the outputs using ZWave, or are they 'linked' to the inputs ?
Kriz
kriz83
Re: Fibaro Binary Sensor FGBS-001
Post by kriz83 »
Nobody knows ?
geert-jan
Post by geert-jan »
The inputs of the binary sensor are directly connected to the output, the output just follows its input. It is not possible no control the outputs independently.
Geert-Jan
uAlex73
Post by uAlex73 »
Other this about this device, if you get the auto-update when the IN/OUT1 or IN/OUT2 is closed, it doesn't tell you the instance 1 or 2 ... So you can only use 1 of them ;-(
Return to “Fibaro”
