Difference eQ-3 Max! radiatorthermostaat
Posted: Sun Nov 03, 2013 11:42 pm
by FoRMaTC
What is the difference between the radiatorthermostaat and radiatorthermostaat
(apart from the price)
http://www.elv.de/max-heizkoerperthermostat-2.html
and
http://www.elv.de/max-elektronischer-he ... ostat.html
Re: Difference eQ-3 Max! radiatorthermostaat
Posted: Wed Nov 06, 2013 12:52 am
by MarnixT
the + version can be programmed without the cube or wall thermostat. If you're a proper home automation enthusiast I guess you want the cube anyway (I wouldn't doubt a second) so then you don't need to spend the extra 5 euro. Just the luxery of programming the system from the laptop is already worth it, let alone controlling it trough webpages / apps etc.
Posted: Wed Nov 06, 2013 1:08 am
by FoRMaTC
Thnx for the explanation. I ordered 2 of them (without the plus), 1 wallthermostat, 2 windows thingies and the cube
Lets see
Posted: Sun Nov 17, 2013 6:15 pm
by marcelrv
Do you know if it is possible to control a eQ-3 radiatorthermostaat (no plus) with an radiatorthermostaat+
I mean that the temp set on 1 unit will control the temp set on the other unit.
This without the cube or wall thermostat.
Haha.... even worse... a true home automation enthusiast uses CUL/Arduino's etc and build his own gateway
Posted: Sun Nov 17, 2013 9:40 pm
by JoopK
This one looks exactly the same?
http://www.bespaarbazaar.nl/radiografis ... -1526.html.
Only double the price?
Sent from my Nexus 7 using Tapatalk 4
Posted: Wed Jan 15, 2014 10:51 pm
by pbrand
The radiator thermostat in this link is not part of the MAX! system, but a separate device for one radiator. You can't control it wirelessly or by software.
