Fibaro switch FGS211 comes to live!
Posted: Wed Dec 04, 2013 11:55 pm
by mrqnapper
Last year I installed a Fibaro switch FGS211 into a wall switch "hotel schakeling". Until last week this set-up has been working great. As off that time, the Fibaro started to live. It's switching on and off on it's own. It will only stop switching, after pushing the off button in Hstouch. Also it responds to the wall switch but not when it starts it's own on and off behaviour.
Has anyone experienced this behaviour? What could be the cause? Might it already be broken, after one year?
Your advise will be appreciated. Thanks.
Wiechert
Re: Fibaro switch FGS211 comes to live!
Posted: Thu Dec 05, 2013 11:45 am
by uAlex73
It also continues when HomeSeer is off/shutdown?
Posted: Thu Dec 05, 2013 12:43 pm
by mrqnapper
tried that, and surprisingly it works as it should. On when switching the light-switch and off again when using the other wall switch. When on it stays on without strange on and off switching. So? Looks like Homeseer is messing things up here ? :)
Than started Homeseer again and wow, looks like it's still working as it should be. Now lets see if it stays like this over time :)
So thanks for your hint uAlex73
Posted: Thu Dec 05, 2013 2:04 pm
by airox
My experience is that the device is default configured to switch on/off when it receives an z-wave ALARM frame.
This could be because of some door-sensor which is removed or not attached suffienctly anymore (which was my case).
It took me some time to find this as well :-)
Hopefully this is also your case...
Posted: Fri Dec 27, 2013 10:04 pm
by Ruud
I had the same isue, because of the water in the elektricaltube there was some " lekstroom" that triggert de fgs211. I had to replace the blacklead and problem solved. after inspection of the black lead the plastic was weakend.
Gr Ruud
