How to monitor current AC Voltage?
alex123
Post by alex123 »
Hello to everybody,
I've been here for a long time but just reading and that's my first post.
I'm searching for a way to monitor the current AC voltage of my house and record the data to my server. Everything is in the pre stage as I'm currently working on my home server so any tips how I can do it will be gladly appreciated.
Thanks in advance,
Alex
b_weijenberg
Re: How to monitor current AC Voltage?
Post by b_weijenberg »
The CM180 measures current an reports a calculated total power
http://www.planete-domotique.com/transm ... n-owl.html
up to 3 http://www.planete-domotique.com/pince- ... ndard.html
or up to 3 http://www.planete-domotique.com/pince- ... large.html
The Revolt NC-5462 can be used to measure the line voltage.
Problem with this sensor is that it transmits about every 4 seconds and a high risk that other sensor signals at 433.92MHz are disturbed.
Akatar
Post by Akatar »
you can use a ups
yjb
Post by yjb »
A typical Solar inverter will also report grid Voltage, so if you have plans in that direction.....
jakkes
Post by jakkes »
@AKATAR...:
How did you manage to get the data in Homeseer?
And what UPS are you using?
I have a APC UPS, with a management card and graph the data with cacti
Akatar
Post by Akatar »
alex123
Post by alex123 »
About the OWL solution, I already have a similar one from current cost but it reports the consumption in Watts not the Voltage.
I don't have any UPS in house.
For solar panels, I have that in mind but still just plans.
alex123 wrote: it reports the consumption in Watts not the Voltage.
The you know enough since P = U x I => I = P / U
P in Watts
U in Volt and probally 220V
alex123
Post by alex123 »
Yes, I know that but since the CurrentCost transmitter is set to 220Volts but here the Volts can varies it report not so accurate consumption. That is one of the reason why I would like to get the voltage value and the other reason is to argue with the electricity company.
b_weijenberg
For this case you can probably use the Revolt NC5462
jeroen_
Post by jeroen_ »
I wanted to write to watch out for newer SmartUPS UPS's, but it seems that apcupsd now has MODBUS support!
http://apcupsd.cvs.sourceforge.net/view ... se-3_14_11
As such, you'll likely be able to use that quite well now to get data out.
(maybe my nasty mails did help in convincing APC to release the protocol details :)
