Reinstall a z-stick
Posted: Mon Apr 28, 2014 2:14 pm
by Wim2008
I have to take a last step to make my new installation of HS2pro on a W7 machine complete. Till now I was using a XP machine. The z-stick was working well on the XP machine.
I have to install the z-stick. It is a v1 stick.
I did the next steps:
- Installed a new HS2pro
- I put in the Z stick
- installed the Aeonlabs software CP210x_VCP_Win7.exe; this was succesfully done
- no extra com port is connect on 'apparaten beheer' of W7 as said in the document of HS (see attache)
- start up HS2pro
- No com port is connected in HS2pro
What did I forget?
B.R. Wim
Re: Reinstall a z-stick
Posted: Tue Apr 29, 2014 10:35 am
by Phaeton
Hi Wim,
you need the comport to be available in device manager (apparaten beheer). Otherwise HS2 will not find it.
Few hints/options:
Windows 7 is available in 32bit and 64 bit. Did you install the driver for the correct bit-version?
Can you unplug the stick and plug it in another usb port? (sometimes helps)
Do you see the stick as an unknown device in the device manager? (then driver issue)
Can you see the stick on your old pc? (the we know the stick isn't defective)
regards,
Posted: Tue Apr 29, 2014 10:45 am
by Wim2008
I use W7 home 32bits now.
I will plugin the stick this evening in another usb port. I haven't try that.
In the device manager of W7 I didn't see the stick as an unknown device, but I will try first another usb port.
On the old XP machine I saw the stick with the software driver as a usb device with port 4.
B.R. Wim
Posted: Tue Apr 29, 2014 11:58 am
by Phaeton
Try it in a USB port on the back first. These are connected directly to the mainbord.
Posted: Wed Apr 30, 2014 8:58 pm
by Wim2008
I did used the wrong driver for the z-stick.
Here is the driver I used now and this one is working fine for W7 home and Aeon Z-stick v1.
See:
http://store.homeseer.com/store/Aeon-La ... -P747.aspx
Do you know if I can use the data in W7 and HS2pro from the z-stick as I used it in XP with HS2pro?
Will all data read in without changing the the data on the z-stick?
B.R. Wim
Posted: Wed Apr 30, 2014 11:16 pm
by Phaeton
Yes, you can import devices again and it should create the devices.
Verstuurd vanaf mijn GT-I9300 met Tapatalk
Posted: Thu May 01, 2014 8:47 am
by Wim2008
Thanks for the information again.
B.R. Wim
Posted: Thu May 01, 2014 11:24 am
by raymonvdm
You can indeed import the information on the stick using HomeSeer (and also other software like OpenHAB/Domotiga)
Note: It is very cheap to upgrade to HS3PRO these days (arround 60 euro)
http://us3.campaign-archive2.com/?u=81f ... 65805c699a
Posted: Fri May 02, 2014 9:16 am
by AshaiRey
Yes it's cheap but have you seen that the amount of zwave problems is still very high?
Posted: Fri May 02, 2014 9:19 am
by raymonvdm
Not only seen but also noticed but someday it should be fixed, are u testing it and if so are u using beta z-wave ?
Posted: Fri May 02, 2014 9:42 am
by Wim2008
It works fine in de new HS2. No changes made. All nodes could be imported from z-stick.
@ raymonvdm:
I use z-wave with the z-stick as a secondair controller.
B.R. Wim
Posted: Fri May 02, 2014 9:56 am
by raymonvdm
Wim2008 wrote:It works fine in de new HS2. No changes made. All nodes could be imported from z-stick.
@ raymonvdm:
B.R. Wim
What type of primary controller are u using ?
Posted: Mon May 05, 2014 2:33 pm
by Wim2008
Primairy controller is the Merten usb-stick.
I like to change that, but till now I don't know how to controll the 2-gang battery devices of Merten in HS2.
BR Wim
Posted: Mon May 05, 2014 6:52 pm
by AshaiRey
I have a very stable HS2 system including Z-Wave and it's up and running without maintainance. So no reason to seek loads of extra work, fustration and a huge drop in WAF any soon
Posted: Mon May 05, 2014 9:13 pm
by Wim2008
HS2 is also running very well with z-wave here. I use the z-stick as secondairy controller and the Merten (Schneider electric) usb-stick as primairy controller.
The last 5 years with Windows Xp and now since a few days with Windows 7 home.
No problems at all with z-wave and HS2.
BR Wim
