Something I always struggle with, is the definition of the address of Micro modules, in this case a S3160M that has lost it's address because a power dip (but also applicable for other modules). What is the correct procedure?
The manual says: press the setup button for 5 seconds (so far so good) and then 'send the adress'. I use my CM15pro or remote control to send an 'ON' command, but module simply jumps out of setup mode after 30 seconds. I tried other commands, but no luck. In the past I succeeded in programming the modules (but it never seems to work at the first try), but now I don't arrive at all.
Kristof.
Define address of Micro Modules
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
