feature request: DHW and CH counters on gateway
blb
Post by blb »
Hi Schelte,
My boiler (Daaldrop Combifort) doesn't support any of the counter values (Pump/Burner starts & Hours). Msg 116, 117, 118, 119, 120, 122 & 123 are all not supported. Would it be possible to generate these counter values based on OT messages if the Boiler doesn't support these messages?
Bernard
Re: feature request: DHW and CH counters on gateway
There isn't a direct relation between the OT messages and the pump, so it would be inaccurate at best. You may be able to get an impression by tracking the status bits CH mode, DHW mode, and Flame status. You will have to do that with an external program though. The gateway doesn't have the resources needed. It doesn't have a clock to measure the time, for example.
blb
Post by blb »
ok, thanks! I'll have a look if I can add counters and timers in Homeseer setup. Burner will be possible, Pump will be difficult indeed.
Bernard
