https://www.spark.io/
very small (2cmx3cm), low cost (US$45) wifi enabled microcontroller : The 'Spark Core' :
The Hardware and software is open source and very much still under constant development.
The wifi module is the Texas Instruments CC3000 module. (Beware : CE certification is only for the chip antenna)
You can set the wifi access point up using your mobile phone or via usb.
The device comes with free ‘cloud services’ for the lifetime of the device, which includes a cloud based compiler, which flashes the device 'over the air'.
Note that compiling/flashing locally, using open source toolchains, is no problem and well documented.
(unlike other similar devices on the market) the cloud functionality is OPTIONAL and you can use it with your own infrastructure or OFFLINE.
(The source code, to replicate the cloud functionality on your own server, is not yet released.)
I discarded other low cost wifi devices, that are currently on the market (or on kickstarter),
that force you to use their proprietary cloud infrastructure (usually for a fee…) (e.g. electric imp etc.)
spark core
Moderator: Mdamen
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
