is there any device like a ZWave plug or wall switch that is empowered with Arduino?
Dario.
Arduino based plugs and wall switches
Moderator: Mdamen
Dario.
Souliss - Opensource Distributed Home Automation and Internet of Things
http://www.souliss.net
Dario.
Re: Arduino based plugs and wall switches
Guessing you want to use Arduino because you like to build things yourself, the Dimmer-Arduino could be a good start.
It looks like there is no ArduinoPlug (like the SheevaPlug) but on the other hand, if you like to use Arduino, some wiring and soldering should be part of the job.
thanks for your answer. Yes Arduino users are supposed to wire something, but there will be a market for devices that will allow people to have products based on their DIY developments. That's why I'm asking if someone knows about.
Dario.
Dario.
Dario.
Dario.
