hi .
does someone know where to get the firmware flash file and software to update / reload flash into the unit ??
I need it as i cannot get access to the pc programmer software ( bad download code ) even after setting back to factory settings.
I have contacted the dealer where i bought it but they cannot / will not help me .
powermax pro flash
Moderators: Rene, Willem4ever
Re: powermax pro flash
You did this?
Remove all power (mains and battery) from the panel.
Remove the panel from its backplate place face down on a cushioned surface.
Identify the two left hand jumper pins marked DEF and fit a jumper across them.
Restore the battery power - this will reset the control panel.
Remove the battery power, and remove the link from the DEF jumper.
Refit the panel and restore the mains and battery power.
Yes . I have just tryed again . still no go .
I have read on some ohter site that the download code should be AAAA . i have tryed this and 1111 , 9999 but none of those works for me .. Im conecting direct to the pins in tcp/ip with a usb to TTL . I have comunication with the unit so i gues it is a wrong code or a need to re-flash
