How to connect a "pulsedrukker" switch to a dimmer
Posted: Sun Sep 21, 2014 9:30 pm
by eggn1n3
I would like to install a Z-wave dimmer to control a light bulb. This dimmer will be built into the wall behind a switch. My question is if I need a so called "pulsedruk" switch to control the dimmer? For example, I looked at the Fibaro FGD211 and Qubino dimmer, but I don't understand how to connect it to the switch. Both dimmers have three inputs for switches. I would expect to use two puls switches; one to increase the light level and one to decrease the light level. Is this assumption right, or don't I understand it correctly?
Thanks!
Re: How to connect a "pulsedrukker" switch to a dimmer
Posted: Mon Sep 22, 2014 11:29 pm
by Phaeton
I use a pulsdruk with fibaro. First short press is on. Double puls is full on. First long press is dim second long press is brighter.
Verstuurd vanaf mijn Nexus 5 met Tapatalk
Posted: Tue Sep 23, 2014 8:45 am
by Henk_J
You can configure the fibaro dimmer to work with a normal switch or with a puls switch. Puls gives you some more possibilities. If i press it for a few seconds the light willl be brighter. If i release and press again for a few seconds the lights will dim, so you will have full control.
Posted: Tue Sep 23, 2014 1:38 pm
by AshaiRey
Which type/model of switch do you use for this?
Posted: Tue Sep 23, 2014 3:43 pm
by eggn1n3
I want to use Fibaro model FGD211.
There are three inputs (S1,S2,Sx) fibaro.com/manuals/en/FGD221-Dimmer/FGD ... .1-2.3.pdf
To dim the light, do I need to use both S1 (more light) and S2 (less light)?
Thanks!
Posted: Wed Sep 24, 2014 8:14 am
by Henk_J
I use the Jung impulsdrukker series. Work fine for me http://www.jung.de/nl/online-catalogus/63920681/
If you use a single pulse switch on the FGD211 then connect it between Sx and S1 and modify parameter 14 to program the correct type of switch to be used.
Posted: Thu Sep 25, 2014 8:36 am
by AshaiRey
Thx,
Which of the 3 do you use because i am a bit confused what i need?
1-polig maakcontact 531
1-polig wisselcontact met N-klem 533 EU
1-polig maakcontact met gescheiden meldcontacten voor signalering 534 EU
Posted: Fri Sep 26, 2014 10:05 am
by Henk_J
Posted: Sat Sep 27, 2014 10:29 am
by AshaiRey
Thanks Henk_J for the info
