HS3 devices - remove status graphics
DJF3
Post by DJF3 »
Team,
When I add a "range graphic" for a battery sensor, it won't show up in the device overview.
Example: Oregon temp sensor or Visonic door sensor
> Range graphic 75-100: battery_100.png
> Range graphic 50-74 : battery_75.png
battery device rfxcom
Screen Shot 2015-11-06 at 9.51.32 .png (15.02 KiB) Viewed 5650 times
The value of the battery device falls within this range but I still see the "standard" battery low icon + text
Other examples: Weight device, temperature devices, Energy devices:
energy device rfxcom
Screen Shot 2015-11-06 at 9.51.16 .png (13.88 KiB) Viewed 5650 times
Is that works as designed or can I change it?
DJF3
Re: HS3 battery sensor - status graphics
Post by DJF3 »
Did more testing with the same result ;-(
DJF3
Post by DJF3 »
Anyone?
