Dear people
I have to couple an energymonitoring system to a domotica device. The main goal is that I can read the graphiques that are given in JSON format by the energywebserver in commandfusion.
I have no idea how I have to program and I need this for my bachelor degree. So far I have been looking everywhere but I can't find a start on anything.
I need a login button
A show graphique button
A log out button
The first button should send this: "http://21.121.123.76:8080/pieter?XP1234&" to the webserver.
The next button should send this: "http://21.121.123.76:8080/pieter?54&0=GetLogDay&16&0&30&"
Note: There should be an instruction that I somehow can change the last 3 numbers. (these numbers are: year & Start day & End day)
when you go to the url above you receive a the requested data in JSON format. The Jason format should be put into a graphique.
The Last button should send this: "http://21.121.123.76:8080/pieter?54&Logout99&"
If anyone can help me a little I might get there. (The urls probably don't work because every system has an other IP en username)
Thanks in advance I appreciate any response
Greetings
Sjorven Van brempt
commandfusion energymonitoring through webserver
Pop your questions regarding Home automation software here.....
- HTTPinstrutieset_JSON_WS500 v6.5 (3).docx
- HTTP instruction (dutch)
- (26.57 KiB) Downloaded 859 times
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
