Toon app: Traffic information
Happy to share the initial release of the stand-alone traffic app. It is mostly based on the official traffic app but doesn't require a live connection to Eneco.
Data is retrieved from http://xml.fileinfo.net/ every 10 minutes, but the screen can be refreshed manually as well.
The screen starts by default with the filter on. Filter in this pack is set at A1, A2, A4 and all N-roads.
You can change the filter via the screen, the new selection is saved in the traffic folder and loaded after a gui-restart as well.
The folder with the app is still called 'traffic' like the original app. If you want to keep the original app I suggest to rename that original folder.
To do:
- create a tile with key data from your filtered traffic jams, need to think about the exact design
- small bug: when opening the screen to change the filter, the N-roads are deselected always. You need to select these again and press Save
As always, happy to hear your feedback.
Kind regardz,
To do:
Kind regardz,
Re: Toon app: Traffic information
small maintenance release.
Changelog:
Version 0.2
- small bug fix regarding selection of N-roads when opening the change filter screen (was unselected by default instead of previous value)
- added a tray icon for quick access to traffic info
- added this changelog
Version 0.1
- initial release
To do:
- add a tile with key data from filtered roads
Kind regardz,
Changelog:
Version 0.2
Version 0.1
- initial release
To do:
Kind regardz,
First full version of the traffic app. Behind the tile you will find the 'standard' traffic app, just heavily changed to work without an Eneco subscription.
You can also get to the traffic info via a new systray icon.
Changelog:
Version 1.0
- added a tile with the first three roads with traffic jams (your road filter is active by default on the tile)
Version 0.2
Version 0.1
- initial release
Happy to take feedback as always.
EDIT: Attachment removed. Application is available for free via the ToonStore.
Kind regardz,
Changelog:
Version 1.0
Version 0.2
Version 0.1
- initial release
Kind regardz,
As of FW version 4.3.20, traffic information has been discontinued by Quby. Of course, support through the Domoticaforum will not stop because of that ...
small update of the traffic app, changelog:
Version 1.0.2
- traffic screen was not initialized properly, started blank always untill you hit the filter button
Version 1.0
Version 0.2
Version 0.1
- initial release
Kind regardz,
Version 1.0.2
Version 1.0
Version 0.2
Version 0.1
- initial release
Kind regardz,
Really thanks for this app. Nice touch to my Toon
Great app, works great. Is it possible to add the A325 to it?
thanks in advance
Qwerk
thanks in advance
Qwerk
That 's easy. On my todo list....
Will show up in the ToonStore when done.
Kind regardz,
Toon,
Kind regardz,
Toon,
thanks, it already showed its first traffic jamToonz wrote:That 's easy. On my todo list....
Kind regardz,
Toon,
thanks, it works, it already showed the first traffic jams an the A325Toonz wrote:That 's easy. On my todo list....
Kind regardz,
Toon,
Hi, this picture shows the traffic tile in normal state as well as in dim state (photoshopped to show both in one picture, not a real full screenshot)PuckStar wrote:How can I get the layout like in this screenshot?
http://imageshack.com/i/pnFPHWjZj
Thanks
A new release (1.0.7) is published on ToonStore.
Changelog 1.0.7:
- now compatible with firmware 4.16.8 (some icons were not shown)
- no need to update when on earlier firmwares (can't harm either)
Kind regardz,
Changelog 1.0.7:
Kind regardz,
version 1.0.9 is available in ToonStore.
Changelog:
- firmware 5 compatibility, no new functionality
Kind regardz,
Changelog:
Kind regardz,
Tested on Toon1 with firmware 5.0.4, this is working fineToonz wrote:Hi all,
Changelog:
Kind regardz,
