Adding Eminent 6570 window contact as binary switch to zipat
tnjkosdomotics
Post by tnjkosdomotics »
I managed to add the Eminent 6570 window contact to my zipabox. This window contact is just a binary switch operated by a reed magnet contact, but can also be used as a generic binary switch. The advantage is that this is a cost efficient solution compared to the dedicated binary swithes from eg fibaro.
You need to add 2 custom parameters in the configuration tab :
EM6570-config.pdf
(125.1 KiB) Downloaded 444 times
Return to “Z-Wave Forum”
