Is version 5.5.7 safe?
Postby Smiggel » Tue May 14, 2019 9:42 pm
I noticed tonight that release 5.5.7 is available. I only can not find the release notes and wondered if it is safe to upgrade.
Smiggel
Re: Is version 5.5.7 safe?
Postby WickedMaster » Tue May 14, 2019 11:32 pm
Yes, it's safe to update.
WickedMaster
Postby TheHogNL » Wed May 15, 2019 4:44 pm
Correct. It is safe (using the TSC update-rooted.sh script or the TSC check update button in the TSC menu).
According to Eneco there is not much changed.
Postby Smiggel » Wed May 15, 2019 5:26 pm
Ok, Thanks guys!
Smiggel
Postby madpatrick » Wed May 15, 2019 9:11 pm
Changes can be found here ( if there are any.......)
https://forum.eneco.nl/software-en-hard ... gaan-21653
madpatrick
Postby michel30 » Thu May 16, 2019 9:16 pm
Update done!
No issue, :D
michel30
Postby Smiggel » Thu May 16, 2019 10:19 pm
Update went smooth. Thanks!
Smiggel
Postby Hussar_303 » Fri May 17, 2019 6:27 pm
I upgraded it as well, everything's fine, congrats to the programmers!
Hussar_303
Postby parapent » Sat May 25, 2019 4:18 pm
After the update i'm stuck at the 1/3 of bootscreen status bar
What i notice sofar:
/etc/inittab is missing
startqt is missing
I don't know how to fix it..
This is the output after the update:
eneco-001-321930:~# curl -Nks https://raw.githubusercontent.com/IgorYbema/update
-rooted/master/update-rooted.sh -o /root/update-rooted.sh
eneco-001-321930:~# sh /root/update-rooted.sh
Welcome to the rooted Toon upgrade script. This script will try to upgrade your                           Toon using your original connection with Eneco. It will start the VPN if necessa                          ry.
Version: 3.87  - TheHogNL & TerrorSource & yjb - 21-5-2019
If you like the update script for rooted toons you can support me. Any donation                           is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
You are currently running version 4.22.7 on a qb2 with flavour uni
Available versions: 1.0.9 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12                           2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.                          0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.                          9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7                           4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.2.11 5.5.7
Which version do you want to upgrade to?
5.5.7
Alright, I will try to upgrade to 5.5.7
Upgrade script downloaded. We need to download the upgrade files first. No upgra                          de is done yet. Do you want me to download the files (yes) or quit (anything els                          e)?
yes
Waiting to finish. Sometimes this takes a minute or two    .
Done preparing.
Are your sure you want to upgrade to 5.5.7 (yes)? This is the last moment you ca                          n stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while... It can take a few minutes.
Bus error 0% .
Upgrade done!
Restoring your iptables and passwd files so you can login again after rebooting.
Upgrade is done. However each firmware upgrade will revert the changes to some files needed for a working rooted Toon. Do you want me me to try and fix a few well known issue's for you right now?
yes
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.5.7.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.4/toonstore_2.1.4-r0_qb2.ipk.
Installing toonstore (2.1.4-r0) to root...
Executing pre-install script for toonstore-2.1.4
Previous installation detected.
Creating backup for /qmf/etc/qmf_release.xml ...
Patching /qmf/etc/qmf_release.xml for 403-forbidden error ...
Restarting http server ...
killall: lighttpd: no process killed
Cleaning garbage....
rm: can't remove '/HCBv2/qml/apps/toonstore/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.jsc': No such file or directory
ToonStore pre-install script completed ...
Configuring toonstore.
Executing post-install script for toonstore-2.1.4 ...
Writing app version number to /HCBv2/qml/apps/toonstore-2.1.4/version.txt ...
Adding toonstore key to opkg keyring ...
OK
This is a Toon 1
No settings to be restored
Removing stale link /HCBv2/qml/apps/toonstore ...
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-2.1.4
Firmware version 5 or greater detected, changing app for firmware compatibility...
Posting message ...
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/easyenergy-1.3.5/easyenergy_1.3.5-r0_qb2.ipk.
Installing easyenergy (1.3.5-r0) to root...
Running preinstall for easyenergy-1.3.5
Older installation detected.
Backing up previous settings ...
Cleaning garbage
rm: can't remove '/HCBv2/qml/apps/easyenergy/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/easyenergy/*.jsc': No such file or directory
Completed preinst script.
Configuring easyenergy.
Running postinstall on /HCBv2/qml/qb/base/Globals.qml
Writing app version number to /HCBv2/qml/apps/easyenergy-1.3.5/version.txt ...
Restoring previous settings ...
Removing stale link /HCBv2/qml/apps/easyenergy
Creating symbolic link /HCBv2/qml/apps/easyenergy to /HCBv2/qml/apps/easyenergy-1.3.5
Posting message ...
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/tsctoonmobile-1.0.6/tsctoonmobile_1.0.6-r0_qb2.ipk.
Installing tsctoonmobile (1.0.6-r0) to root...
Executing pre-install script for tsctoonmobile
lighttpd.conf backup already exist, leaving it in place...
tsctoonmobile pre-install script completed ...
Configuring tsctoonmobile.
Executing post-install script for tsctoonmobile....
Removing stale link /HCBv2/qml/apps/tsctoonmobile ...
Creating symbolic link /HCBv2/qml/apps/tsctoonmobile
restarting lighttpd....
Posting message ...
tsctoonmobile post-install script completed ...
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/boilerstatus-1.0.6/boilerstatus_1.0.6-r0_qb2.ipk.
Installing boilerstatus (1.0.6-r0) to root...
Running preinstall for boilerstatus-1.0.6
Deleting garbage ...
rm: can't remove '/HCBv2/qml/apps/boilerstatus/*.qmlc': No such file or directory
Configuring boilerstatus.
Executing post-install script for boilerstatus-1.0.6 ...
Writing app version number to /HCBv2/qml/apps/boilerstatus-1.0.6/version.txt ...
grep: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Adding boilerstatus to Globals.qml
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Removing stale link /HCBv2/qml/apps/boilerstatus
Creating symbolic link /HCBv2/qml/apps/boilerstatus to /HCBv2/qml/apps/boilerstatus-1.0.6
Writing dummy boilervalues.txt to allow creation of symlink...
Creating symbolic link /HCBv2/www/boilerstatus/boilervalues.txt to /var/volatile/tmp/boilervalues.txt
ln: /HCBv2/www/boilerstatus/boilervalues.txt: File exists
Posting message ...
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/temperaturelogger-1.3.4/temperaturelogger_1.3.4-r0_qb2.ipk.
Installing temperaturelogger (1.3.4-r0) to root...
Cleaning garbage
Configuring temperaturelogger.
Running postinstall on /HCBv2/qml/qb/base/Globals.qml ...
Adding temperaturelogger to Globals.qml ...
Removing stale link /HCBv2/qml/apps/temperaturelogger ...
Creating symbolic link /HCBv2/qml/apps/temperaturelogger to /HCBv2/qml/apps/temperaturelogger-1.3.4
Posting message ...
Done with post-installation script
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/buienradar-8.4.1/buienradar_8.4.1-r0_qb2.ipk.
Installing buienradar (8.4.1-r0) to root...
Running preinstall for buienradar-8.4.1
rm: can't remove '/HCBv2/qml/apps/buienradar/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/buienradar/*.jsc': No such file or directory
Configuring buienradar.
Executing post-install script for buienradar-8.4.1 ...
Writing app version number to /HCBv2/qml/apps/buienradar-8.4.1/version.txt ...
Globals.qml is up-to-date
Removing stale link /HCBv2/qml/apps/buienradar
Creating symbolic link /HCBv2/qml/apps/buienradar to /HCBv2/qml/apps/buienradar-8.4.1
Posting message ...
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/wastecollection-4.24/wastecollection_4.24-r0_qb2.ipk.
Upgrading wastecollection on root from 4.20-r0 to 4.24-r0...
Running preinstall for wastecollection-4.24
Done with preinstall sript
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/textielDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/iconHide.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/best.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/qmldir.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/EditTextLabel4421.qml.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/wastecollection.js.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/WastecollectionConfigurationScreen.qml.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/grootvuilDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/puinDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/pmdDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/lang/lang_en_GB.qm.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/WastecollectionApp.qml.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/version.txt.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/WastecollectionTray.qml.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/snoeiafvalDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/kunststofDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/gftDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/Changelog.txt.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/WastecollectionListDatesScreen.qml.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/waste_menu.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/collectContainerDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/waste_icon.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/icon_delete.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/kgaDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/lang/lang_nl_NL.qm.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/iconBack.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/papierDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/restafvalDim.png.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/WastecollectionTile.qml.
Removing obsolete file /HCBv2/qml/apps/wastecollection-4.20/drawables/edit.png.
Configuring wastecollection.
Removing stale link /HCBv2/qml/apps/wastecollection
Creating symbolic link /HCBv2/qml/apps/wastecollection to /HCBv2/qml/apps/wastecollection-4.24
Posting message
Collected errors:
* remove_obsolesced_files: unlinking /HCBv2/qml/apps/wastecollection-4.20/version.txt failed: No such file or directory.
* remove_obsolesced_files: unlinking /HCBv2/qml/apps/wastecollection-4.20/Changelog.txt failed: No such file or directory.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/spotenergy-2.0.2/spotenergy_2.0.2-r0_qb2.ipk.
Installing spotenergy (2.0.2-r0) to root...
Running preinstall for spotenergy-2.0.2
Cleaning garbage
rm: can't remove '/HCBv2/qml/apps/spotenergy/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/spotenergy/*.jsc': No such file or directory
Configuring spotenergy.
Writing app version number to /HCBv2/qml/apps/spotenergy-2.0.2/version.txt ...
Removing stale link /HCBv2/qml/apps/spotenergy
Creating symbolic link /HCBv2/qml/apps/spotenergy to /HCBv2/qml/apps/spotenergy-2.0.2
Posting message ...
EDITING: Adding serial connection
Everything done! You should reboot now!
eneco-001-321930:~#
What to do?
parapent
Postby mAiden » Sat May 25, 2019 6:54 pm
parapent wrote:After the update i'm stuck at the 1/3 of bootscreen status bar
startqt is missing
5.5.7
yes
Done preparing.
yes
Bus error 0% .
Upgrade done!
yes
OK
This is a Toon 1
Posting message ...
Cleaning garbage
Posting message ...
Posting message ...
Posting message ...
Cleaning garbage
Posting message ...
Posting message ...
Posting message
Collected errors:
Cleaning garbage
Posting message ...
eneco-001-321930:~#
What to do?
Send me a PB, can you possibly help via teamviewer :)
mAiden
Postby parapent » Sat May 25, 2019 9:38 pm
mAiden wrote:[
Done! thanks
parapent
Postby TheHogNL » Sun May 26, 2019 8:19 am
parapent wrote:/etc/inittab is missing
startqt is missing
How did you reboot after the update? The logs looks fine.
I assume you did a power cycle instead of giving a 'reboot' command.
Postby mAiden » Sun May 26, 2019 10:42 am
startqt is missing
No idea what the reason was. Inittab was empty, and qt-gui was missing.
Fill the inittab agian and install qt-gui with the VPN on. Now hes Toon is booting agian.
mAiden
Postby parapent » Mon May 27, 2019 7:53 pm
startqt is missing
After the update, I rebooted with the "Shutdown now -r" command. Right after that the bootscreen freezed.
No errors before the update.
Everything works again, thanks for helping me out mAiden, and for your work on the script TheHogNL.
parapent
Return to Toon Firmware
cron
