Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Postby Toonz » Wed Feb 26, 2020 9:24 am
memo1996 wrote:Jah dat ik het gedaan inderdaad anders zou ik geen gegeven zien. Ik mis alleen RFT dus restafval
just had a look and I see what's going wrong, they combined gft/restafval date is shown as GFT only. I need to split this entry in two separate ones.
Will be done shortly
Postby Toonz » Wed Feb 26, 2020 9:44 am
version 4.38 is published in the ToonStore.
Changelog:
- Almere fix: proper handling of combined collection dates for Restafval and GFT
no need to update for other users.
Kind regardz,
Postby dacronic » Wed Feb 26, 2020 9:50 am
New Toon user here, i have an empty Afvalwijzer screen after configurating the app. Tried different sources, filled in
the adres etc but no data is shown. Waited a day, updated the firmware. Reinstalled the app. Any suggestions?
dacronic
Postby Toonz » Wed Feb 26, 2020 10:00 am
dacronic wrote:Hi,
wow, that's a lot of actions :-)
In which city do you live?
Postby dacronic » Wed Feb 26, 2020 10:51 am
sorry, tried everything i could do at that moment :(
I live in Alkmaar, postcode 1825.
dacronic
Postby Toonz » Wed Feb 26, 2020 12:17 pm
Postby memo1996 » Wed Feb 26, 2020 12:58 pm
Het werkt helaas niet ik zie nog steeds geen Restafval.
Toonz wrote:Hi all,
Changelog:
Kind regardz,
memo1996
Postby Toonz » Wed Feb 26, 2020 1:05 pm
after update of the app to the new version you will see the new data only after a few minutes or when you go to the settings screen and press 'opslaan '
Postby memo1996 » Wed Feb 26, 2020 1:27 pm
Ik zie geen update via ToonStore klopt dat?
Duurt dat even voor dat het beschikbaar is voor mij?
Toonz wrote:after update of the app to the new version you will see the new data only after a few minutes or when you go to the settings screen and press 'opslaan '
memo1996
Postby memo1996 » Wed Feb 26, 2020 1:32 pm
Jah, ik zie het al gedaan en het WERKT!
Dankjewel
memo1996
Postby Toonz » Wed Feb 26, 2020 1:37 pm
memo1996 wrote:Ik zie geen update via ToonStore klopt dat?
Haha, nee , wij zijn geen Eneco die releases moeten toekennen aan gebruikers :D .
Als ik iets vrijgeef in de ToonStore met je zelf even op het refresh icoon klikken in de ToonStore als je het direct wilt binnenhalen.
Maar goed dat het nu werkt in ieder geval.
Postby memo1996 » Wed Feb 26, 2020 1:42 pm
Kan ik ook icoontjes erbij zetten? Dus dat je bijvoorbeeld vuilniszak plaatje erbij ziet?
memo1996
Postby dacronic » Wed Feb 26, 2020 1:44 pm
Is this also the solution for my issue from Alkmaar?
dacronic
Postby Toonz » Wed Feb 26, 2020 3:20 pm
memo1996 wrote:Kan ik ook icoontjes erbij zetten? Dus dat je bijvoorbeeld vuilniszak plaatje erbij ziet?
If you enable 'Show icons in thermostaat panel' in the settings screen you will see the icons above the temperature.
Or put the tile on your homescreen, which will show the icons in dim state.
N.B. Icons are changed everydat at 18:01 to show the waste collection for the next day.
After a restart of the gui, the icons will only be shown 6 minutes after restart,
In other words, if you configured the settings today, icons will only start showing at 18:01 today if waste is collected tomorrow.
If you want to see the icons earlier do restart the gui after configuring the app and wait 6 minutes.
The 18 hours moment can also be configured in the settings screen but will only take effect the next day.
Hope this clarifies
Postby Toonz » Wed Feb 26, 2020 3:22 pm
dacronic wrote:Is this also the solution for my issue from Alkmaar?
I answered your question about Alkmaar a few post above.....
PreviousNext
Return to Toon Apps
