Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Postby Toonz » Wed Nov 18, 2020 10:00 pm
jvdheuvel wrote:I try to get the afvalkalender of Uden in the Afvalwijzer app.
As far as I know, Uden is not supported by the afvalverwerkers that are already implemented in the app.
Can this also be implemented in the app?
https://www.uden.nl/inwoners/afval/opha ... PK-65.html
I also downloaded the .ics file, only I cannot find how to upload the file to my Toon.
I noticed there should be a description in the Manuals section, however I cannot find it.
Can someone please help me out with this?
Thanks in advance! :-)
You have to copy your ics file to Toon and rename as /root/waste/waste_calendar.ics (can be done via ssh or tools like WinSCP).
If the folder waste doesn't exist in root you have to create it manually.
Next, in the settings screen of the app you have to select waste provider 25 and that's it
(25 is areaafval.nl, happens to use exactly the same format)
In a future release I will change the app to retrieve the file automatically for you....
Kind regards,
Postby jvdheuvel » Thu Nov 19, 2020 10:16 am
Kind regards,
Thanks!
I installed WinSCP and tried get into the Toon, however that doesn't work (or, most likely, I don't use the correct settings).
I bought a rooted Toon and I don't know what the credentials are to log in with SSH
Once I am in, I guess the rest will not be that hard to do... all seems to be quite straightforward....
Are the login credentials normally standard values or something completely else?
Any suggestions what I can try to enter?
Support for our afvalverwerker in the next release would be great.... that way I only need to select the right afvalverwerker, set mij postal code and house number and it will be collected automatically I understand?
Any idea when the new release will be available?
jvdheuvel
Postby Toonz » Thu Nov 19, 2020 10:36 am
typical login credentials :
user root
password toon
use the scp protocol on port 22 with WinSCP
no timing on the next app release yet...
Postby jvdheuvel » Thu Nov 19, 2020 10:49 am
That worked!!
Thanks.... :)
jvdheuvel
Postby jvdheuvel » Thu Nov 19, 2020 10:58 am
Toonz wrote:typical login credentials :
user root
password toon
Thanks! that worked to login.... just have to set the waste provider to 25 when I'm back home and it should work :)
jvdheuvel
Postby Toonz » Thu Nov 19, 2020 12:36 pm
jvdheuvel wrote:Thanks! that worked to login.... just have to set the waste provider to 25 when I'm back home and it should work :)
after copying the ics file, yes....:-)
Postby senaja » Mon Dec 07, 2020 9:47 pm
Christmas trees are picked up in my street on January 6 and 13. The waste calendar does not know this and indicates unknown. How do I fix this?
senaja
Postby Toonz » Tue Dec 08, 2020 11:46 pm
senaja wrote:Christmas trees are picked up in my street on January 6 and 13. The waste calendar does not know this and indicates unknown. How do I fix this?
The app currently does not have a specific icon and description for christmas tree pickup, that's why you see unknown.
Postby senaja » Wed Dec 09, 2020 10:42 am
I thought so too, but how do I fix this so that it works properly?
senaja
Postby Toonz » Wed Dec 09, 2020 11:48 am
you cannot resolve this yourself without programming. It requires some coding changes in the app and a new icon in the resourcefile.
(it is not high on my to-do list to be honest)
Postby Toonz » Wed Dec 09, 2020 2:02 pm
a solution could be to show the christmas tree collection dates as the existing type 'Snoeiafval'. For that I need to know your wasteprovider / city to make the adjustment.
Postby senaja » Wed Dec 09, 2020 8:26 pm
Toonz wrote:a solution could be to show the christmas tree collection dates as the existing type 'Snoeiafval'. For that I need to know your wasteprovider / city to make the adjustment.
The waste processor is HMS and the city is The Hague
senaja
Postby Toonz » Wed Dec 09, 2020 9:33 pm
And I was thinking they build huge fires in the Hague with the christmas trees...:-)
any way , will have a look later this week
Postby senaja » Thu Dec 10, 2020 4:35 pm
Toonz wrote:And I was thinking they build huge fires in the Hague with the christmas trees...:-)
Good. Thank you. Otherwise we can start huge fires with the Christmas trees in The Hague ... :-)
senaja
Postby Toonz » Thu Dec 10, 2020 8:12 pm
version 4.50 is available in the ToonStore with a fix for denhaag.nl users: kerstbomen are now shown as 'Snoeiafval' instead of 'onbekend'.
No need to update for other users.
Kind regardz,
PreviousNext
Return to Toon Apps
