Opentherm option
Opentherm option
Postby Joskep » Wed Nov 25, 2020 10:55 am
Hello, short question:
on my rooted v2 i see that its not possible to change the setting OPENTHERM, its always GREEN (on).
This morning (everything worked fine) is saw that the icon of ' using hot water' dind' t show up while using hot water.
After touching the OPENTHERM setting it worked and it did show up while using hot water.
But i don't see it changing while clicking on it.
It isn't a problem, but i wanted to know why this is :D
Greetz
Joskep
Re: Opentherm option
Postby TheHogNL » Wed Nov 25, 2020 12:19 pm
You can not change to opentherm by switching it 'on'.
You can only press the 'refresh' button to let the toon redetect if opentherm is working. If it detects opentherm then the switch will go to the left to point that opentherm is used.
Postby Joskep » Wed Nov 25, 2020 2:09 pm
ok, clear!
Maybe the refresh did the trick then, thanks!
Joskep
Return to Toon Apps
