Opentherm option
Joskep
Opentherm option
Post by Joskep »
Hello, short question:
on my rooted v2 i see that its not possible to change the setting OPENTHERM, its always GREEN (on).
This morning (everything worked fine) is saw that the icon of ' using hot water' dind' t show up while using hot water.
After touching the OPENTHERM setting it worked and it did show up while using hot water.
But i don't see it changing while clicking on it.
It isn't a problem, but i wanted to know why this is :D
Greetz
Re: Opentherm option
Post by TheHogNL »
You can not change to opentherm by switching it 'on'.
You can only press the 'refresh' button to let the toon redetect if opentherm is working. If it detects opentherm then the switch will go to the left to point that opentherm is used.
Joskep
Post by Joskep »
ok, clear!
Maybe the refresh did the trick then, thanks!
