Toon app: Afvalwijzer
Moderators: marcelr, TheHogNL, Toonz, TerrorSource
Re: Toon app: Afvalwijzer
Probably something wrong at Meerlanden.nl or the waste2api platform.
I can't get your calender either, the provided links via the website are not working
flamingbob
Post by flamingbob »
Hi Toonz,
Thank you for the update. Been offline for a while for some personal reasons. Will also check or poke them to fix it. Thanks!
whizzz63
Post by whizzz63 »
Hi, is it possible to add RWM to the app?
whizzz63 wrote: Fri May 13, 2022 3:54 pm Hi, is it possible to add RWM to the app?
RWM.nl is using mijnafvalwijzer.nl.
Select provider 1 in the settings screen and fill in your postcode/housenr
whizzz63
Post by whizzz63 »
Thanks, it works!
