Toon for Android
AnD!
Re: Toon for Android
Post by AnD! »
RoadXY wrote:
ipster wrote:I have re-done update-rooted.sh and now the app is connecting fine. I did root my toon manually, so maybe i missed something. Just thought i should let you know in case you have done something similar
Thanks.
Could be an firewall issue on the Toon...
Hi! I'm afraid I'm going to ask a beginner's question :( Why does the Android app work when you're at home (wifi) but not when you're away from home? :S What can be done to fix this? Thanks again!
gerlag
Post by gerlag »
Hi all. I wanted to be able to manage the rooted Toon from the Internet by port forwarding the router and adding user/password in lighttpd (password external toon only, so toons internals stay still working normally), and also using an always free ddns service (Dynu) with a valid ssl certificate of letsencrypt. That's all put together and working now, Maybe I'll post a HOWTO soon in the forum. (couldn't find something similar on the forum yet)
However.. I'm using the app Toon for Android (rooted), it works excellent with user/password restrictions on a (redirected external) http port, but - sadly- it appears (or seems) that the app is not supporting ssl so it can not be used on the redirected https port. Using http from the internet, the app still exposes user/password.
I's beyond my knowledge, but maybe it's possible to add ssl support to the app?
If yes, then it's really safe to use the app external from any place, even open wifi form airport.
gerlag
Post by gerlag »
I tried to ask the question a week ago... Did'n pass the moderators. Don't know why. So now again: I managed to have a working ddns service and ssl (letsencrypt) on my Toon 1, so I now have (real) safe external acces to my Toon. I would like to use Toon for Android, but the app appears to only accept http connections, no https.
Would it be possible to add https in Toon for Android? Then a real safe remote control with Toon for Android is possible.
witteherder
Post by witteherder »
I still have a big problem with making contact with Toon2
I did put the right local ip address on my phone which is also connected with the same SSID Wifi
My phone is getting only this
"Even geduld"
Even geduld aub terwijl we proberen verbinding te maken met de Toon thermostaat.
I wanted to show a picture of the phone but the pixels are to low to upload.
I did check on the Toon 2 for the right ip address 192.168.2.15 local and port 80
Toon 2 Rooted User
Firmware version: 5.94.7
Raspberry Pi 3B+
Domoticz 2022.1
10 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
Avi
Post by Avi »
My toon for Android worked as i installed it.
I havent used it in the summer.
Now i want to use it but it doesn't show any data.
If i delete the app the same happens
If i try tot log on it keeps saying connecting to server
In the app it gives the following problem:
There is been a error when connecting to toon
Com.android.volley.volleyerror:
Java.lang.illegal.argumentexception: Name is empty
I got a screenshot attached
Patrickg
Post by Patrickg »
Will there be an app for ios the iphone or ipad?
Cheers
oepi-loepi
Post by oepi-loepi »
There are no plans or actions from TSC side. So if anyone like to create it and have it in the apple store it will be brilliant.
EricvL
Toon for Android gone from the Playstore
Post by EricvL »
Hi everybody,
The Toon for Android app seems to be removed from the Playstore. Does that mean that there's no more active development?
Kind regards,
Eric
oepi-loepi
There is a lot of development going on. The new app for sonos has just been published. And there is also the /mobile app wich works for all platforms.
Bruce the boss
Post by Bruce the boss »
Can you give me the link for the mobile app because I really can't find it?
EricvL
Post by EricvL »
oepi-loepi wrote: Fri Apr 28, 2023 11:47 pm There is a lot of development going on. The new app for sonos has just been published. And there is also the /mobile app wich works for all platforms.
Hi @oepi-loepi,
Yes, there may be a lot of development for Toon apps, but not for the Toon for Android app, which I was referring to. It's now even gone from the PlayStore...
oepi-loepi
EricvL
Post by EricvL »
oepi-loepi wrote: Fri May 05, 2023 11:12 pm https://github.com/Inversion-NL
Weird... This site lists version 0.7.1. I'm running 0.7.2, which was the latest version back in the days when it was available through the Playstore.
