First of all HVXL thank you for a OTGW module that has been working very well for many years.
This summer I moved to my new home.
I took the OTGW (V4.2.5 / date: 20-10-2015) from my old home and installed it in the new hardware setup:
- Intergas Kombi Kompakt HReco 36
- Honeywell modulation: T87M2018 (1603)
The setup is working pretty well.
I can monitor/control the setup using the opentherm monitor.
The only thing missing is that I cannot monitor the CH water pressure and the DHW temperature and setpoint.
As you can see in the attachment.
When I take a look at the equipment details for ( Intergas Kombi Kompakt HReco; Honeywell Round Modulation T87M2018)
I can see that the ketel can provide the messages and that the thermostat is also compatible with, ID=18/26/48.
I think I'm doing something wrong here.
As one of the first steps in an attempt to debug the problem is upgrading the firmware of the otgw to V5.8 but this didn't solve the problem.
Could you point me in the right direction how to be able to read the water pressure from the ketel>
OTGW - Get CV water pressure
- Knipsel.PNG (158.99 KiB) Viewed 3514 times
Re: OTGW - Get CV water pressure
The Honeywell round modulation thermostat provides only very basic functionality. It doesn't (need to) use many different Opentherm messages to be able to do that. So it doesn't request MsgIDs 18, 26, and 56. To obtain that information from the boiler anyway, you can instruct the OTGW to periodically request that information by running the AA=18, AA=26, and AA=56 commands.
For the AA commands to have any effect, there must be some messages from the thermostat for which the boiler returns Unk-DataID. I couldn't tell from your screen shot if that is the case.
I first checked if I see the Unk-DataID appear in the logging. -> This is true for MsgID=14 I executed the command:
21:58:55.749435 Command: AA=18
21:58:55.804328 AA: 18
Next thing i did is trying to force msgid14 as unknown id
22:00:02.083618 Command: UI=14
22:00:02.151383 UI: 14
22:01:09.160164 Command: UI=25
22:01:09.224303 UI: 25
22:01:50.395501 Command: PM=18
22:01:50.411431 PM: 18
I attached the logging in the zip.
The OTGW is running in monitoring mode ( firmware version 4.3)
- logging28-12-2023.zip
- (21.84 KiB) Downloaded 213 times
That's the problem then. As the name suggests, in monitor mode the OTGW can not make any changes to the message exchange between the thermostat and the boiler. It only monitors the messages. So, in this configuration, the thermostat fully controls what information you get.
Why did you decide to put your OTGW in monitor mode?
I thought you had updated the firmware to 5.8. Why did you go back to 4.3?
The reason for downgrading the firmware to version 4.3 is because the logging displays Data-inv messages when processing data from message ID 5 or 2.
I downgraded to version 4.3 and noticed that the Data-Inv messages remained.
Didn't bother to upgrade back to version 5.8 yet.
Actions taken:
- Switched OTGW to gateway mode. The reason it was in monitor mode is that monitoring mode was working fine for me in the old situation.
- Send AA=18 again.
- monitored logging. The Unk-DataID remains showing up but no MsgID=18
- Using TP=18 doesn't seem to force a request for msg-id=18.
Are there any other settings that need to be configured in a certain way to make the AA message work?
10:44:32.540785 T00110000 Read-Data Relative modulation level (MsgID=17): 0.00
10:44:32.635793 BC0110000 Read-Ack Relative modulation level (MsgID=17): 0.00
10:44:33.540705 T1002010D Write-Data Master configuration (MsgID=2): 00000001 13
10:44:33.630396 BE0020000 Data-Inv Master configuration (MsgID=2): 00000000 0
10:44:34.541697 T80190000 Read-Data Boiler water temperature (MsgID=25): 0.00
10:44:34.632905 B40191AA1 Read-Ack Boiler water temperature (MsgID=25): 26.63
10:44:35.540200 T10010A00 Write-Data Control setpoint (MsgID=1): 10.00
10:44:35.632574 BD0010A00 Write-Ack Control setpoint (MsgID=1): 10.00
10:44:36.540021 T80000200 Read-Data Status (MsgID=0): 00000010 00000000
10:44:36.631147 B40000200 Read-Ack Status (MsgID=0): 00000010 00000000
10:44:37.539782 T00110000 Read-Data Relative modulation level (MsgID=17): 0.00
10:44:37.629520 BC0110000 Read-Ack Relative modulation level (MsgID=17): 0.00
10:44:38.540697 T00050000 Read-Data Application-specific flags (MsgID=5): 00000000 0
10:44:38.629271 B60050000 Data-Inv Application-specific flags (MsgID=5): 00000000 0
Actions taken:
- Send AA=18 again.
Log?
Firmware version 4.3 is nearly 3 years old, and there have been several newer versions since then. So I don't remember the exact details, but I'm quite confident that the AA command was already working back then.
Let me also try to clear up some misconceptions you appear to have:
- Data-Inv is a type of message sent by the boiler. Changing the firmware version of the OTGW has no influence on that.
- The default mode of the OTGW is gateway mode. You get the most benefit from the device by leaving it at that default mode. You should only switch to monitor mode when gateway mode is not working correctly.
- Switching between modes does not make the OTGW forget the AA commands that you entered before. You will now have multiple entries for MsgID 18 in the list of alternatives.
- TP=18 is not a valid command. You probably want PM=18.
I didn't have much time to investigate the issue further the last couple of weeks.
Last week there was a poweroutage.
After the poweroutage was restored the cv water pressure messages were present.
I manually powercycled the otgw before but that didn't work.
This time it worked.
Thanks for your time and help!
