Plugwise Homeseer Plugin
Moderators: Rene, RdP
In the configuration screen of the plugin you can select whether or not to use the names and/or locations as defined in the Plugwise Source server. When you want to define other names and/or locations in the plugin you should uncheck these options.
Edwin2008
Post by Edwin2008 »
thanks, will try
Rene,
I have upgraded without any problem.
Charts looks great also on my Imac after installing the silverlight
Response feels a bit better..not sure if any thing is changed in the switching part.
Thanks
Viper1970
Post by Viper1970 »
Hi Rene,
new version works great!!
thanx and regards
Chander
Rene,
I like to use the charts in HSTouch.
Is there a possibility to write the chart to a png file from an event?
simjoc
Post by simjoc »
Ik doe iets verkeerd, waar kan dit aan liggen?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
31-1-2009 12:32:01 - Plugwise - ERROR: No MAC Address known for device
31-1-2009 12:32:31 - Plugwise - ERROR: No MAC Address known for device
31-1-2009 12:33:01 - Plugwise - ERROR: No MAC Address known for device
31-1-2009 12:33:31 - Plugwise - ERROR: No MAC Address known for device
@simjoc: This is difficult to determine just from these log entries. Possibly you do not have installed the database correctly. Is it possible to send me the complete log in a PM?
@chak: I also rather have images in png format. However Visifire offered an easy to implement method to provide charts. I will look into any alternatives.
simjoc
Post by simjoc »
Sorry for the Dutch language in previous post. Send the log in e-mail to you.
The only difference is one sentence:
31-1-2009 13:42:32 Plugwise DEBUG: Query: http://localhost:81/statistics.xml
31-1-2009 13:42:32 Plugwise DEBUG: Parsing statistics.xml
31-1-2009 13:42:32 Plugwise ERROR: No MAC Address known for device
simjoc
Post by simjoc »
With the help of Rene everything is working now. It was a problem with the port. The port 81 (plugwise) wasn't working. When using 8080 it is working :)
Ruud
Post by Ruud »
Rene help,
Install 3 time's over but error no mac adres know for device
gr Ruud
Ruud,
When you request the URL of the Plugwise Web server without the static.xml page, does it return the web interface of Plugwise (most likely not). The webserver of Plugwise is a bit buggy and probably does not run as it should in your setup. You have to mess a bit with the web server configuration in the Plugwise Source server untill it is possible to access the Plugwise web interface. As soon as this is possible, the homeseer plugin should also work. The error message you are getting is caused by the Plugwise web server returning something for the statistics.xml page, but not the output it should.
Ruud
Post by Ruud »
Rene,
The web interface of plugwise 192.168.1.200:8080 respond normal.
gr Ruud
What do you get when you request the statistics.xml page, http://192.168.1.200:8080/statistics.xml?
Ruud
Post by Ruud »
Rene,
<?xml version="1.0" encoding="iso-8859-1" ?>
- <items type="array">
- <appliance>
<moduleid>Module['000D6F00002371E3']</moduleid>
<datetime>2-2-2009 15:25</datetime>
gr Ruud
This is the output of the statistics.xml file from the 0.2 version of the plugin. You have to install the new version of statistics.xml that is part of the 0.3 package.
