Connecting the TSU 9600
Thanx, now we're getting somewhere...
Did you request access to the Professional area, since i still can't find the pdf myself...[:I]
- Snelvuur
- Forum Moderator
- Contact:
Yes, i'am level 1 certified pronto installer now (you have to be really dumb not to be able to get it) answer a few questions online and your in..
http://www.binkey.nl/~rf/digit/ just grab the pdf from here then.
Thanx again! I applied for professional access too a few moments ago.
- Snelvuur
- Forum Moderator
- Contact:
About the tcp connection, if someone has to much time. Try and see if you can grab http://www.vid.nl/VI/_rss the traffic at the moment. Since i'am still having a bunch of issues.
Also digit, your tcpsend works, but for some reason the response is slow on the logs of the webserver. As if the call is not disconnected but kept open for a long period of time. Just noticing though.
Erik,
I think i know what causes the slow response.
I use this script to connect with a TCPServer that disconnects the client automatically, right after processing the command and sending a reply. Your webserver doesn't close the connection itself, so you'll have to do the Close() yourself. Wild guess: 1 of the 2 parameters for the socket.read() is a timeout value...
I'll try to find some time later this evening for the traffic.
Robert.
PS.
Page 38 of the PSDG.
Robert.
PS.
Here you go:
I had 2 problems:
- didn't know the System.print only shows the first 99 characters, so for a long time it looked as if just a small portion was received...argh!
- added some extra header fields to simulate a "real" browser; without these header fields i got back a 404.
Have fun...[:D]
Robert.
function GetURL() {
var result = "";
var socket = new TCPSocket(false);
socket.onConnect = function()
System.print("OnConnect");
socket.write("GET /VI/_rss HTTP/1.1\r\n");
socket.write("Accept: */*\r\n");
socket.write("Host: www.vid.nl\r\n");
socket.write("\r\n");
socket.onData = function()
System.print("onData");
result += socket.read();
socket.onClose = function()
System.print("onClose");
while ( result !="") {
System.print(result);
result=result.substring(98);
socket.connect('www.vid.nl', 80, 3000);
Have fun...[:D]
Robert.
- Snelvuur
- Forum Moderator
- Contact:
ok, so i created a label called "vid" then added a button which calls "GetURL();" and i added "CF.widget("vid").label=result;" but when i push the button nothing shows up. How do you test your code? Since the only thing i know is just putting it on the pronto and having a go, which is really slow.
Here's the xcf. Just push the buttons...
It's not very fancy, but at least you can see what has been received in the result-variable.
Robert.
Hmm, attachment type not allowed i guess. I'll mail it to you.
Robert.
He Robert
nice work.
can you also send a message to me with the xcf file?
I'm working on dutch TV logo's i will post this soon.
Pieter: can you make possible to post xcf files?
nice work.
- Snelvuur
- Forum Moderator
- Contact:
http://fotos.binkey.nl/main.php/v/autom ... 9.JPG.html now thats just nice to have
shows whats on t.v. now and later. If you press the info button you get a small text about the current show.
