problem dix1
problem dix1
I have 9 dix1 in my home 6 of them works fine no problem at all but the other 3 will not send dim or bright comands. I have programed them several time but it doesn't work.
has anybody some ideas
problem dix1
Try switching a working DIX1 with a not working and then program it again. Then you are sure it's not the quality of your powerline.
problem dix1
I try that, that works fine. With AMX en the ctx35 or the hcb I can controle then without any problem.
problem dix1
Hi Harmb,
Check this topic http://www.domoticaforum.eu/topic.asp?TOPIC_ID=56
You probably have some glitches in the powerline, I have them to some of my outlets I just can't reach. Now I have a 3 phase powerline which is even worse. You could measure the quality of the X10 signal across your powerline.
So you have the AMX panel with the CTX15 included? Nice equipment!
Regards Pieter
Regards Pieter
- Snelvuur
- Forum Moderator
- Contact:
problem dix1
I would suggest if you have a 3 phase powerline and a special FKX fase couplet (http://www.elekhomica.nl/product_info.p ... ucts_id=49) that should be enough to have good signals around the house without any great issues right? Or the EH-ARC3?
problem dix1
I have only 1 phase powerline. Its also strange that the cable lenght no longer is then 10m in the room where i have my problems. the problem exist from day one after installing at that time there where no electric equipment in my home i was rebuilding my home.
problem dix1
Again it's always possible that some outlets can not be reached with a strong enough signal. You can measure the signal strength with a Xanura PUX. This however is a expensive device. I know there are some other measuring devices but I don't know the exact details. I have some outlets as well that I can not reach. I'm know going to try to solve it with a XANURA XVS10, this is a modules which boost the signal to the required level throughout a complete phase.
Pieter
Pieter
problem dix1
I have a 3 phase powerline and had also some problems.
After installing the FKX ( http://www.elekhomica.nl/product_info.p ... cts_id=491 ) everything works fine for me.
Antoon
Antoon
- Snelvuur
- Forum Moderator
- Contact:
problem dix1
Whats the diffrence with the FKX and http://www.elekhomica.nl/product_info.p ... cts_id=217
Only is like 30 euro difference, and it says for micro modules? the repeating function?
problem dix1
So far as i know there is no difference inside,only the price.
problem dix1
Hello, here iám again. Some of my DIX1 has some problem whit recieving the program code. when i program dim and one other function the dix1 dont recieve the dim function. I can program all other exept the dim funtion. when i program only the dim function the dix1 recieved it good.
has anyone seen this problem aswell?
