This weather clock provides the data you need to plan your day—including weather forecast, precise Atomic time, day, indoor temperature and outdoor temperature with trend indicator. Instead of displaying all information at the same time, this smart weather clock uses motion sensor technology to detect how close you are to the device before displaying select information. The current time, day and weather forecast display in large digits and icons when you are far away from the weather clock. As you approach the unit, the Weather In Motion switches to showing the indoor and outdoor temperature readings, while the time and weather forecast icons automatically reduce in size. You can also set to auto “scroll” mode and the display will smoothly shift the information every five seconds.
