Can someone help with some examples for properly results for a graphic from electricity?
This the one for the last 60 minutes.
Could it be easier?
SELECT twatt, MINUTE(ttime) FROM elec ttime > SUBTIME(curtime(), '01:00:00') AND tdate = CURDATE() ORDER by tdate DESC, ttime ASC LIMIT 60"
After midnight, it will not show the previous day results...
I can'y see the logic with SQL... and want a easy table in SQL
for the moment, i have; date, time, devicecode, valueofcounter, watt
And i'm using chartdirector...
thanks!
SQL SELECT statements...? week/day/24h
Here's an MS SQL example for a 24-hour power usage chart.
i : "index" or position on the x-axis.
x : the values on the x-axis (the hours like 0, 13, etc.)
y : the y-values (the power usage)
I use a datetime type for the time field and store a start- and endvalue in every record.
You'll have to do some rewriting for MySQL i guess (limit instead of top etc.) but if you get the bigger picture it won't be that hard to alter this to your needs.
Succes,
select top 24
datediff(hour,[time],getdate()) as i,
datepart(hour,[time]) as x,
(EndValue-StartValue)/1000 as y
from data
where lgDeviceID = 'RFXP3'
order by time desc
Succes,
the TOP 24 is LIMIT 24 in MYsql btw... for other users..
I understand what you mean, but i want the results inversed.
With your example, the latest results are in the graph at the left side.
I want it from old -> new (Left -> right)
How about this then:
restrict the records returned by the WHERE, not the TOP and then you can use another field for sorting:
select
from data
where lgDeviceID = 'RFXP3' and datediff(hour,[time],getdate()) < 24
order by i desc
select
from data
order by i desc
