Weet iemand of het hiermee mogelijk is om een spreek/luisterverbinding te maken via het internet tbv alarmering.
Barix Annuncicom 100
Network intercom and PA component for commercial, industrial and security applications
At Barix, the sky is the limit when it comes to communication. Barix Annuncicom is an interface that bridges audio to Ethernet to allow people to communicate with each other and to inform others. You could call it an IP intercom and IP paging system.
Features
Transmits voice, pre-recorded announcements, alarm messages and music over the network to any specific location
Two way communication is possible just like an ordinary intercom
Communicates over a standard network connection (10/100 Mbit/s) and supports TCP/IP-Protocol
Incorporates an integrated Web server for control and configuration
Works in combination with other Barix Annuncicoms as an autonomous IP Intercom, IP Paging system or can be used by itself with a PC controlled solution
Applications
IP paging, IPintercom and IP alarm system
Commercial IP audio distribution
Residential IP audio distribution
