Custom Infrared Codes
Cariba
Post by Cariba »
I have a WinLIRC (IR Receiver) compatible device attached to my PC.
Now I want to generate custom IR command with a small amount (e.g. device address) of data embedded in the IR signal to be received by the PC.
Anyone got any suggestions on encoding (for instance) a value of 0x8038BDF5 to an IR signal. I would need a Pronto Hex code as a result value.
Does anyone has some suggestions on how to accomplish this?
on the next url look voor HEX converter..Maybe you can create the codes you want using this tool.
http://www.hifi-remote.com/sony/Sony_rcvr.htm
RdP
Post by RdP »
Look at http://www.remotecentral.com, here is lots of info about all kinds of remotes and IR codes to find....
Cariba
Post by Cariba »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><br />on the next url look voor HEX converter..Maybe you can create the codes you want using this tool.
There is no hex converter there...
Yeah I already looked at that page but I couldn't find what I was looking for. I might end up coding something myself or using existing codes for a different purpose...
sorry it's called makehex (download form remotecentral)
http://www.hifi-remote.com/sony/Sony_pronto.htm
