Klipsch LightSpeaker
Snelvuur
Post by Snelvuur »
http://www.engadget.com/2010/01/05/klip ... s-screwin/
When we walked the sound-filled halls of Klipsch's Indianapolis headquarters last month, the company insisted that it was always looking at possible expansions into new markets. Today at CES, it's proving that those words aren't being uttered carelessly. The all-new LightSpeaker is a unique and potentially game-changing device in the whole home audio market, as unlike similar contraptions, this one requires no external wiring or power. The device is designed to fit into normal 5- to 6-inch light recesses, which enables existing homeowners to easily retrofit these into their ceilings and walls. We were granted some hands-on time with the light, and put simply, you just screw it into a conventional fixture, dial up the desired zone on the bundled remote, and listen. A full-range driver sits just beneath the LED light, and it receives signals via a 2.4GHz base station that can be plugged into just about any source.
Klipsch plans to ship these soon in two main packages: a kit that includes a base station and two LightSpeakers for around $600 and a single LightSpeaker by its lonesome for around $250. The bundled controller allows users to control two zones and two sources, and you can also adjust lighting brightness and volume via the main station or the smaller remote. Each zone can easily support four LightSpeakers, and when we asked if these could withstand the elements, we were told that they'd do fine in a covered patio but probably not within an unshielded pool deck. In other words, some humidity shouldn't be an issue, but you probably wouldn't want 'em to get rained on all night. We also wouldn't be surprised to see a bundle in the future that includes a wireless subwoofer to really round out the audio, but don't say you heard it from us.
