Duwi outside usage
Duwi outside usage
I need some zwave modules for in the garden.
Idea is place them in a IP65 housing (kabeldoos)
http://www.overtoom.nl/hensel-kd-kabeld ... 07516.html
what do you think?
Re: Duwi outside usage
I've done the same last summer with a Xanura and a PLCBUS module.
They are in the left box. Works ok, no problems (yet).
Robert,
What kind of box is it?
I have several AW12's in an IP65 box for over 2 years now without any problem.
@Enver, i think it was this one: http://www.conrad.nl/goto.php?artikel=521144
Robert,
Thanks..I need a bit smaller version.
there are several options.
I also have a adapter inside for a pump, so that's why i chose a big one; you can get several different dimensions.
I used the following box and 2 AW12's to build 2 controlled power outlets:
Return to “Z-Wave Forum”
