The meter of water consumption
Moderator: b_weijenberg
Does anyone have an idea how you can measure water consumption at the water meter in belgium
Or has anyone a picture of the sensor on the water meter
the water meter belgium have no reflection plate
is is about water meter white 5 white numbers and 3 red numbers
bart
bart
Re: The meter of water consumption
Hi , it's like the italian device. i think that you should find a new (digital flow meter) AFTER the official one . Lorenzo
this has a digital output : it works with many flow meters togheter , has wifi too.
http://www.aquatech-systems.eu/index.ph ... er-reading
Ed, how does it calculate the pulse from flow meter? with rfxcom?
- Jeroen Bartels
- Advanced Member
@ Janseb,
I have the same meter as you have and you can measure the water usage.
There is a small black cover (not the one covering the numbers). Take it out and you have 2 holes. (I think I see it 1 cm to south west of the orange mark.)
Put a reed contact into one of the holes and you get a pulse every 0,5 liter.
I tried to find the original reed contact but it's hard to get. You might as well buy a really small reed contact from Conrad.
http://www.conrad.nl article 502036
It's not cheap but it's better than replacing the water meter.
good luck.
good luck.
**Jeroen**
JayBee wrote:@ Janseb,
It's not cheap but it's better than replacing the water meter.![]()
good luck.
I can confirm the above works fine.
regards, the other Jeroen
The meters give a pulse for 1puls/liter
The have also a version for 0,5L/puls
In the RFXmeter you make a device RFXwater and voila its works
Ed
Ed
Thanks to everyone to help me
bart
bart
Jeroen(en), any pictures available so we can see how things fit together?jeroenkl wrote:I can confirm the above works fine.JayBee wrote: I have the same meter as you have and you can measure the water usage.
- Jeroen Bartels
- Advanced Member
No picture available as I have some ducktape keeping the reed contact in place.
Just take the black cap off and you will see 2 holes. The rest was explained.
Drop me a PM if you want me to explain it to you by phone.
**Jeroen**
I have fond the hols to put in the readcontact it is on the right side of the red numbers
approximately half of the meter
I will try to make a picture this evening
bart
bart
anoder option look on the photo i have indicated on the photo
mine is on the site of the red numbers dis photo is the old type of water meters
- Jeroen Bartels
- Advanced Member
In my meter the 2 holes are right next to each other. One hole is for the reed contact and the other hole is used to fix the housing of the original reed contact.
However if you buy a normal reed contact (eg. from Conrad) you don't need the second hole.
You might have to test how deep to insert the reed contact by opening the watertap and measure if the contact opens and closes while water is running.
**Jeroen**
Attached 2 pictures of my setup.
JeroenKl
JeroenKl
- P1020389.JPG (158.16 KiB) Viewed 10638 times
- P1020390.JPG (158.72 KiB) Viewed 10638 times
