Battery Merten Switch and Homeseer
Wim2008
Re: Battery Merten Switch and Homeseer
Post by Wim2008 »
I have only one problem with the Merten push button 2-gang:
In homeseer both gangs are there, but only with 1 gang I can work. The 2de gang has no status. See image.
How can I change that?
B.R. Wim :) :wink:
Wim2008
Post by Wim2008 »
abl, who do you mean with Danish guy?
B.R. Wim :) :wink:
bierk
Post by bierk »
Is the above possible without the Aeon stick but using the the Merten USB device instead?
Wim2008
Post by Wim2008 »
No, in the Merten software you see 2 switches.
B.R. Wim :) :wink:
Wim2008
Post by Wim2008 »
I have done an update from HSpro 2.4 to 2.5 and the problems with the 2-gang push button are disappeared.
Both buttons from the Merten 506219 are now seen in the staus of HS and also be used.
Marvellous for the users of this switch. Has other people the same experients?
See also http://www.domoticaforum.eu/viewtopic.p ... 190#p47851
Because it is very important to do what Enver told me about recanning the zwave devices.
B.R. Wim :) :wink:
Return to “Z-Wave Forum”
