High CPU usage Homeseer
Moderator: Ruud
phoenixb
Post by phoenixb »
I have sinds a short month that when HS is running for about 1 week that HS is getting for about 60 to 70% usage of my CPU.
I have not change anything that can be the problem, so my question what is the best way to resolve this problem?
__________________
Alexander
Re: High CPU usage Homeseer
Post by Alexander »
DJ,
Have the same problem, but i do know the cause at my place: polling the zwave modules.
Alexander
Bjochems
Post by Bjochems »
Do you use the PHNetwork plugin?
Bas
Snelvuur
Post by Snelvuur »
I've had also high cpu, this was also because of polling z-wave devices. If i poll all my devices the events just wont run correctly anymore (lights jump on after 5 seconds instead of almost instantly when motion is detected)
phoenixb
Post by phoenixb »
I have Z-wave but i'm polling every 60sec. at this moment so i think this can not be the problem.
But i have running PHNetwork so what can i do to solved it (ok disable the plugin ;-) only that is not the sollution)
__________________
Snelvuur
Post by Snelvuur »
btw, at the moment when it polls all the devices.. if you have a motion z-wave device for instance going through homeseer, it will be slow/annoying delays.. dont know if they will fix that though.
i also once had some debugging still turned on, which created something like 400gb of text data cant remember which one it was (but you can check your homeseer folder to look for big files)
Bjochems
Post by Bjochems »
djdive wrote: But i have running PHNetwork so what can i do to solved it (ok disable the plugin ;-) only that is not the sollution)
I don't have these problems with PHNetwork but I know some forum members do.
When you disable the plugin for some days and you see no high CPU usage anymore you can assume the plugin is causing the problem. Then you at least know that the plugin is the problem...
Bas
