Repository - Sample Images of Cameras
Moderator: Esteban
Mobotix MD10
Highly compressed, resolution at 1280*960
Bwired Mobotix MD10 at night.
[/img]
Bwired Mobotix at night
Esteban
Post by Esteban »
LYIPC-08B
Specs:
- PC-CAM + IP-CAM
- M-JPEG
- Install ActiveX Control: yes
- PTZ [Pan/Tilt/Zoom]
- 20 fps for VGA
- 300K Pixels CMOS Sensor
- Motion Image Resolution: 640 × 480
- Auto Exposure
- Auto White Balance
- Auto Gain Contro
- HTTP/DHCP/IP/TCP/UDP/DDNS
- Operation Voltage: 5.0V
- Power Consumption: 500mA
Product link:
http://www.ec66.com/ad_IPCamera/index.asp" onclick="window.open(this.href);return false;
Day Image:
Credits: drmacchi
Esteban
Re: Repository - Sample Images of Cameras
Post by Esteban »
Axis p1346
Comments:
-Looks like it applies some sort of 'Median Cut' filter to the image, cutting down on noise, but alson on image detail.
Specs:
http://www.axis.com/files/datasheet/ds_ ... 012_lo.pdf
- 0.6 lux (color) 0.08 (B&W)
- max res: 2048x1536px
- varifocal
- cs lens mount
- two-way audio
- 30fps in 2MP and HDTV 1080p, 20fps in 3MP mode.
Manual:
http://www.axis.com/files/manuals/um_p1 ... n_1007.pdf
Day image:
Full res (no recompression) piece of image showing 'Median Cut'-type filtering, especially visible in the trees:
Night Image:
Credits: AenG
drmacchi
Post by drmacchi »
Qihan VS-1163N SNH-2HQ1
Specs:
http://www.qihan.cn/en/pdf/Waterproof/VS-1163N.pdf
http://www.qihan.cn/en/contents/11/80.html
- 540TVL, PAL:752x582 / NTSC:768x494
- 1/3‘’Sony Super HAD CCD
- Varifocal 4-9mm
- 48 IR LEDs
- Operating temperatures -10℃~ +50℃
- Storage temperatures -20℃~ +60℃
- IR reach: 30-45 Meters
- IP65
- Signal to Noise Ratio: >52dB
- 1/50(1/60)—1/100,000(Sec.)
- Dimensions: 270*164*142mm
- Weight: 1500g
- BNC camera bought on ebay for 149 euro.
http://cgi.ebay.it/Telecamera-TVCC-540T ... 8465962875
Manual zoom, good IR. resolution is 358 or 640, camera is BNC so this is the resolution done by the DVR where are connected 9 BNC cameras. Note that outside it's completly dark! No lights, only trees and forest.
Dayshot at 358px, with rain:
Nightshot at 358px:
Nightshot at 640px:
I'm also upgrading the other cameras system and i bought one of these , very cheap, but it seems interesting. 1280 resolution , wifi etc..
http://www.grand.com.tw/pdf/SpillResistant_camera.pdf
Screenshots of wifi cam As soon as possible. Ciao !
Esteban
Post by Esteban »
Mobotix T24M-Sec-D11/ N11 (Video Doorbell)
Comments:
- SIP support
- 180 degree FOV
- 2048x1536 Color (D11) or 1280x960 Black&White night-version (N11).
- Integrated DVR
- IP65
- Sensitivity: 1lux(t=1/60s)/ 0.05lux(t=1/1s) (D11 model) / 0.1lux(t=1/60s)/ 0.005lux(t=1/1s) (N11 model)
- Virtual PTZ possible
- 20/30fps depending on resolution used.
Manual:
http://www.mobotix.com/eng_GB/file/2628 ... 100614.pdf
Daytime shots 'D11' model:
Somebody at the door
Full sensor coverage
Virtual PTZ
Nighttime shots: (none available)
More information:
http://www.networkwebcams.com/ip-camera ... ment-23966
(@1m50s)
Credits: networkwebcams.com & Thorsten@ knx-user-forum.de
The T24 is for a while on my list, great device!
jrkalf
Post by jrkalf »
WatchBot
Comments:
- IR leds
- Wifi or Ethernet
- Two-way audio
- Pan, Tilt
Manual:
Revision 4 - januari 2012: http://www.mygadgetsandgifts.co.uk/watc ... de_eng.pdf
Revision 3 - December 2011: http://www.mygadgetsandgifts.co.uk/watc ... ec2011.pdf
Up close, 20cm range, full dark, image taken by the watchbot (foscam rebranded FI8908W or FI8918W, still unknown)
ELV FHT80b heating system.
Edwin2008
Post by Edwin2008 »
Elro C903IP
Comments:
- Wireless/ Wired : Both
- Wireless digital/analog : Digital
- Camerasensor : ¼” CMOS
- Resolution (Pixels x Pixels) : 320x240(QVGA), 640x480 (VGA)
- Lens : f:6mm, F:2,0
- Light sensitivity (Lux) : 0,5Lux
- Nachtvision LEDs : 24x IR LEDs
- Videoformat : MJPEG
- Adjustable framerate : 30fps@QVGA, 15fps@VGA
- Power supply : 230VAC/5VDC, 2,0A
- Power consumption : <5W
- Operational temperature (°C) : -10° ~ + 40°
Manual:
http://www.elro.eu/uploads/products/man ... Manual.pdf
Only disadvantage is the large connection plug. Needs a hole of appr. 35mm
Day
Night
More Information:
http://www.elro.eu/products/category/be ... erkcamera1
** edwin **
ludom
Post by ludom »
EasyN Dome Camera
Cheapass Indoor (I use it outdoor under an roof) Dome Camera I bought once on Ebay (I think for 60 dollar).
Day:
Night (with porch light), cam has no IR:
Night (without light), cam has no IR:
Image quality is very bad by night and less light, time to buy something better :lol:.
Home-brewed HA system based on Linux, PHP5, MySQL and Beanstalkd
neomess
Post by neomess »
Foscam FI8905W
Specs
  • Resolution: 640 x 480 Pixels(300k Pixels)
    Image Sensor: 1/5" Color CMOS Sensor
    Display Resolution: 640 x 480 Pixels(300k Pixels)
    Mini Lumination: 0.5Lux
    Lens Type: Glass Lens
    Image Compression: MJPEG
    Image Frame Rate: 15fps(VGA),30fps(QVGA)
    Flip Mirror Images: Vertical / Horizontal
    Light Frequency: 50Hz, 60Hz or Outdoor
    Video Parameters: Brightness, Contrast
    Ethernet: One 10/100Mbps RJ-45
    Wireless Standards: IEEE 802.11b/g
    Wireless Security: WEP & WPA & WPA2 Encryption
    Infrared Light: 60 IR LEDs,Night visibility up to 30 metres
    Storage Temperature: -10°C ~ 60° (14°F ~ 140°F)
    Storage Humidity: 0% ~ 90% non-condensing
    CPU: 2.0GHZ or above (suggested 3.0GHz)
    Memory Size: 256MB or above (suggested 1.0GHz)
    Display Card: 64M or above
    Supported OS: Microsoft Windows 2000/XP/Vista / 7 / 8 / Mac
Manual:
http://www.foscam.com/Private/ProductFi ... ual-46.pdf
Day picture: (picture taken at 15:20)
Night picture: (picture taken at 18:40)
Foscam FI8904W Xtra (The Xtra stands for a special model with 2.8mm lens that gives the camera a 60 degree angle)
Day picture: (picture taken at 11:35)
Night picture: (picture taken at 04:00)
2014-01-03 18-14-15_large.jpg (29.72 KiB) Viewed 52321 times
2014-01-03 15-20-35_large.jpg (52.24 KiB) Viewed 52321 times
Visit my realtime website: http://www.neomess.nl
Justin Renzom
Post by Justin Renzom »
Some pics seem grainy... :roll:
Edwin66
Post by Edwin66 »
Cropped a bit
Cropped a bit
< cropped for size.
Digoo W02F (cheap camera from China, It's cloud-based, but with some DNS knowledge, you can block the home-calling).
Image(at night 6 IR)
Image(Day-time)
Toon® (rooted) | Hue bulbs | TRÅDFRI bulbs | Smart Plugs | some TUYA stuff |
I'm not a programmer, just wish things work MY way
