Globaltronics/QUIGG Plugin modules
Moderator: b_weijenberg
hhg
Post by hhg »
Hi
Newbie, first question, hopes this is the rigth place...
Does anyone know these Plugin Modules: (See attached image).
They are 3-4 years old, bougth in ALDI. Marketed by Globaltronics GMBH, Hamburg.
According to the box documentation they operate on 433,92 Mhz.
So the biq question: Can they be controlled by RFXCOM?
Best Regards
hhg
QUIGG Plugin Modules
esschenk
Re: Globaltronics/QUIGG Plugin modules
Post by esschenk »
Hello.
If you can open the device and look for the chipset
If this is PT2262/PT2272 chipset
Then it will work.
Most off this remote switch are working with the same chipset
Good luck
Ed
dan
Post by dan »
Did you made any progress with the quigg?
gul1773
Post by gul1773 »
I'm not the guy that began that thread but I have the same issue. I've jut opened the wall plug and I can't identify any transmetter ; if I send you a picture, will you be able to help me ?
forward thanks
Guillaume
