Just starting out with HStouch and in the midst off installing my z-wave equipment and configging it for Ipad version on HStouch.
I configured my alarm events and put them on "Disable Automatic Event Triggering". I'd like to "enable" them with the use of an HStouch button.
In HStouch designer I only find an action "trigger a homeseer event". When I use this the event triggers regardless of the trigger conditions I put in there.
Question: how do I enable ]automatic event triggering in HStouch without triggering the actual event? (i.o. without bypassing the set conditions).
Any help would be much appriciated!
"enable" automatic event triggering without triggering?
Re: "enable" automatic event triggering without triggering?
Solved this with the use of a script file which enables and disables my event's. Problem solved!
